Old 09-27-2022, 06:20 AM   #1
russcc
Default EV8 Parts to Hershey
City: Bourne
State: MA
Price: In ad
KELSEY- Hayes, Set of 5, 16”, 40 Bent spoke wire wheels, good spokes, lug & valve holes. set $875.
’40 – 16” x 4” wheels, - Very good used wheels, all good lug & valve holes, Pair $95..
'36, ’68-3580 Steering box, professional rebuild, $175.
‘38-39 – Swan shift lever, w/spring, cup washer, cap and nice vintage EV8 shift knop. $175.
‘40-48 – LZ Gear Set, O6H-7113 26T cluster, O6H-7017.18T Main drive gear.
O6H-7102 24T 2nd, Gear. All good used from the same transmission. $685. Also, spare 18T main & 24T 2nd.gears.
‘40-48 – 81A-7017, 16T main drive gears, some with good bearings, 81A- 7102 2nd gears, 68-7113 28T clusters, all good used gears, and many other good used transmission parts.
’46-48 – Lincoln brakes – Deep backing plate adapters to Ford spindles, pair $200. Lincoln backing plate emergency brake cable tubes/plates, pair $95.
’39-41 – Restored Lockheed brake backing plates, several pairs, front & rear complete w/shoes, linings, springs, grease baffles, and hardware. - $300. a pair, Also some ’restored 46-48 backing plates.
’32-34 – Hub/Drums, good used, front & rear, many good miles left in them, several sets or individual ones. $50. Ea.
’40-48 – Brake drums, O1A/21A-1125, NORS, front or rear, fits over the O1A hub, several pairs, $175. a pair.
Timing Covers - 3 Bolt & 2 bolt, NOS & good used, $25 -$50. Ea.
Lincoln Zephyr – Used, magnafluxed iron cylinder heads, gasket sets, fair prices.
Manley Performance , New SS Hi Flow valves, flathead, intake valve, 1.600 head OD, Same stem OD as Ford, aprox. .060 longer, ideal reground cam valve – Set of 8, $95. Have additional spares.
Miscellaneous -
Vintage Stewart Warner 160 MPH Speedometer - $175.
‘58-62 C1 Corvette valve cover, good condition, 1 only, $75.
‘58-62 C1 Corvette front bumpers, good condition, pair, $75,.
’65 Porsche, NOS retracting ash tray, $75.
Contact [email protected] for photos. Parts pickup, only at Hershey, Chocolate field, C4S-35.
These parts are from a 40’ container of spares purchased from the Michael Dingman collection. In addition, from that container I have numerous restored axle housings, NOS 59AB intake manifolds & heads, used chassis running gear & powertrain parts.
I will bring parts to Hershey on personal request. Please email me with your request, and I will send you my cell phone #.
Russ
russcc is offline   Reply With Quote
