Old 09-16-2022, 06:38 PM   #1
russcc
Default Backing plate bolt source
Does someone have the part or part #s for the square head bolt that fasten the backing plates, (2013 F, & R 2213, 2214) to to the front spindle-3105 & rear axle housing , and includes the baffle 2240 in the '39-'48 brakes. ? I don't find them in the Green Bible or 3rd Gen's Fordbolts. Thank you, Russ
russcc is offline   Reply With Quote
Old 09-16-2022, 06:51 PM   #2
TJ
TJ's Avatar
Default Re: Backing plate bolt source
Did you caLL third Gen? He may have them NOS
Old 09-16-2022, 07:05 PM   #3
Kube
Super Moderator
Kube's Avatar
Russ, I have a ton of them. Which ones do you need exactly? How many of each?
Old 09-16-2022, 10:19 PM   #4
Steve Seidl
Steve Seidl's Avatar
Cool Re: Backing plate bolt source
[B]Suggest you Check out CW MOSS Ford parts-cwmoss.com.I just purchased some backing plate bolts from them.
Steve Seidl is offline   Reply With Quote
Old 09-17-2022, 06:03 PM   #5
russcc
I got a couple good ideas where to get them, thank you. But, I would still like to find the part #s & description in the Green Bible if they are in there.
Old 09-17-2022, 06:25 PM   #6
russcc
Looks like I found the part #s in the Green Bible, 59a-2056, 1/2-20 x ,820 fronts, and 59a-2249, 1/2-20 x 1.120, rears.
Old 09-18-2022, 03:34 PM   #7
Mart
Mart's Avatar
Depending on the year, the lower bolts may be longer than the top bolts as they have to pass through the radius arm. 37-48 for example.
Mart is online now   Reply With Quote
Old 09-18-2022, 04:00 PM   #8
35fordtn
35fordtn's Avatar
We have the fronts and the upper rears listed on our website
35fordtn is offline   Reply With Quote
