Old 09-14-2022, 08:01 PM   #1
Smitty
Smitty's Avatar
Default 1950 Ford Tudor 226 6 cyl Heater System
Hi All,
On the 226 6-cyl does the coolant flow from the water pump fitting to the heater control on the firewall or from the cylinder head to the heater control on the firewall? Green bible is not clear on this.
Thanks, Steve
Smitty is offline   Reply With Quote
Old 09-16-2022, 08:51 AM   #2
scooder
Default Re: 1950 Ford Tudor 226 6 cyl Heater System
In my experience, the water pump hose goes to the upper firewall (heater) inlet and the cylinder head hose goes to the lower firewall it fitting. I've found this to be true on very wide selection of vehicles.
Hope this helps.
Martin
scooder is offline   Reply With Quote
Old 09-16-2022, 11:05 AM   #3
Dan in MI
Dan in MI's Avatar
Scooder is correct. Adding the heater control in the circuit the coolant flows from the cylinder head (hot coolant) to the passenger side of the heater control then out the drivers side to the lower nipple of the heater core. Coolant (cooler coolant) then flows out the top heater core fitting to the water pump inlet. Here it mixes with the cooler coolant from the radiator and cycles back through the engine.
Dan in MI is offline   Reply With Quote
Old 09-17-2022, 06:16 AM   #4
Smitty
Smitty's Avatar
Dan,
Looks like you have a Ford, is this how yours is setup, hot from the head going to the heater control first then out to the heater core, finally from the heater core to the water pump?
Steve
Old 09-17-2022, 08:34 AM   #5
Dan in MI
Dan in MI's Avatar
Yes but mine is a V8. That is the way it is plumbed. This came from the "The 1949-50-51 Ford Book" from The Early V8 Club of America page 5-16. You want the highest temp water going to the control valve first (so there is no hot water in the core during the summer). The return from the water pump is on the suction side of the pump (inlet).
Old 09-17-2022, 08:53 AM   #6
Dan in MI
Dan in MI's Avatar
Here is a flow diagram that may help.
Old 09-17-2022, 08:54 AM   #7
flatford8
flatford8's Avatar
I believe going in the bottom fitting and out/returning from top fitting, helps to purge the air trapped in the heater core……Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 09-17-2022, 10:57 AM   #8
Smitty
Smitty's Avatar
I am thinking what makes sense is for the hot leaving the head then to control valve then to core and return to the water pump. First stop being the control valve then to heater core.. You can shut off flow of hot coolant to heater core.
Old 09-17-2022, 09:46 PM   #9
FortyNiner
FortyNiner's Avatar
The flow for 226 in my '49 F1 (with a control value) looks like this:
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 09-18-2022, 08:35 AM   #10
Smitty
Smitty's Avatar
On your picture above: The On the large straight line coming out of the control valve (top), where does that line go? The bottom line coming out of the engine, does that connect directly to the heater core? The last one goes between the heater core and the curved outlet on the control valve.
Old 09-18-2022, 02:22 PM   #11
FortyNiner
FortyNiner's Avatar
Top line from water pump to temp valve
Middle line from temp valve to heater core
Bottom line from heater core to head
Old 09-19-2022, 12:50 PM   #12
Smitty
Smitty's Avatar
Sounds correct as Shoebox had described it. Does hot water flow from water pump or from head?
Old 09-20-2022, 06:29 AM   #13
FortyNiner
FortyNiner's Avatar
All of the coolant is hot in my view. The water pump pushes coolant and the head is just a return path.
Old 09-20-2022, 09:02 AM   #14
Zeke3
Zeke3's Avatar
In my experience, the supply to the heater is from the head and the return is to the water pump inlet, suction side of the pump.
Zeke3 is offline   Reply With Quote
Old 09-20-2022, 01:11 PM   #15
Smitty
Smitty's Avatar
That's the way I read it, first to get hot is line from the head.
