Old 08-19-2022, 06:29 PM   #1
Jacques1960
Jacques1960's Avatar
Default Inertial third brake light - suction mounted
A friend at the Pinetree Jamboree had a suction mounted battery powered inertial (mercury switch ?) third brake light.
No manufacturer identity on the case.
Would appreciate any help sourcing as it seemed to do the job and be easily moved between cars.
Thank you.
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 08-19-2022, 09:07 PM   #2
38bill
38bill's Avatar
Default Re: Inertial third brake light - suction mounted
Maybe check out Google. I know they make them for bicycles.
Here are some available on Amazon:
http://https://www.amazon.com/s?k=bicycle+brake+light+with+sensor&crid=2HBPECWWL 62RB&sprefix=bicycle+brake+light%2Caps%2C895&ref=n b_sb_ss_ts-doa-p_2_19
38bill is offline   Reply With Quote
Old 08-20-2022, 06:40 AM   #3
Jacques1960
Brilliant - thank you !
Old 08-20-2022, 08:39 AM   #4
Bob/Pa
Bob/Pa's Avatar
I bought one years ago on Ford Barn, has suction cups and 4 bulbs, mercury operated when hit brakes. Works great.
Bob/Pa is offline   Reply With Quote
Old 08-20-2022, 09:02 AM   #5
JimG
JimG's Avatar
Sounds interesting. The one 38Bill references on Amazon are all for bicycles - don't see how you would easily apply any of those to a car. Bob - can you identify your source, or Jacques - can you ask your friend?
JimG is offline   Reply With Quote
Old 08-20-2022, 10:51 AM   #6
Jacques1960
That’s the exact one - suction cup mounting. He thought the name might have been something like Brake-lite (?)
Old 08-20-2022, 11:00 AM   #7
19Fordy
19Fordy's Avatar
Here's some suction cup mounted 3rd brake lights as revealed by Mr. GOOGLE.
Mercury switch not mentioned.
https://www.google.com/search?q=suct...hrome&ie=UTF-8
Old 08-20-2022, 11:09 AM   #8
nelsb01
nelsb01's Avatar
Can they even sell Mercury these days?
I would check out Brake-Liter -- love mine and I even have it set up to work with turn signals.
Best part, is the guy sent me one to test, and if he didnt hear back from me in a week, he would then charge my card. If I didnt like it, I let him know and then send it back.
nelsb01 is offline   Reply With Quote
Old 08-20-2022, 11:35 AM   #9
Jacques1960
Those look nice, but this was cordless and activated by stopping - likely a mercury switch. Really slick.
Main body was only about 4” wide, perhaps 5” with the suction cup brackets.
The bicycle versions referenced above look very similar, save for the suction cups
Old 08-20-2022, 05:09 PM   #10
Jacques1960
Uncle Bezos has something called BikeSpark which looks like the ticket, absent the suction cups . Shouldn’t be too hard to fab a mount
Old 08-20-2022, 06:16 PM   #11
Jacques1960
Have ordered and will report back with photos
Old 08-21-2022, 09:27 AM   #12
farmertom
farmertom's Avatar
i agree with nelsb01,i too have a brake-liter kit installed on my '37 fordor split window. all the distracted and tailgators wake up when you tap the brake before actually stopping. its remarkable how it works. Tom.
farmertom is offline   Reply With Quote
Old 08-21-2022, 10:54 AM   #13
19Fordy
19Fordy's Avatar
farmertom: Thanks for posting. Please let us know where we can purchase the brake-liter kit you speak of.
This is what I found but, it requires wiring.
https://www.brakelighter.com/
Here's the no wire bike light set up.
https://www.amazon.com/BikeSpark-Aut.../dp/B0991V426W
Old 08-21-2022, 01:15 PM   #14
Bob/Pa
Bob/Pa's Avatar
The one Jac1960 is talking about is the one I have. No name so trying to find the paper work for it.
Old 08-21-2022, 03:18 PM   #15
farmertom
farmertom's Avatar
yeah,19Fordy that is correct website for brakelighter,and it does require wiring fairly easy. on my "37 fordor i made a 1/4" size hole in cardboard package tray and run the entire wire harness down to underside of car study carefully how to get to wires you need to tap into.you will find that you will use most of the length up.Tom
Old 08-21-2022, 03:19 PM   #16
19Fordy
19Fordy's Avatar
Looking forward to your reporting back.
Old 08-21-2022, 04:22 PM   #17
Y-Blockhead
Y-Blockhead's Avatar
I installed a Flasher Module on the third brake light on my '30 Town Sedan and my '55 Ranchwagon to wake up the person behind me. It flashes the light three times then stays solid. 12v only tho.
https://www.amazon.com/United-Pacifi...s%2C235&sr=8-2
Old 08-21-2022, 07:00 PM   #18
Bob/Pa
Bob/Pa's Avatar
Found it, the one with suction cups and 4 led's, mercury operated is from company TopServeLLC, , [email protected], www.brakeflasher.com. I purchased 2017 for $23.99. works great
Old 08-22-2022, 08:02 AM   #19
Jacques1960
Thank you very much; checking to see if these are still available
Old 09-01-2022, 04:48 PM   #20
Jacques1960
Wanted to report back on my progress.
“Brake Spark” makes a rechargeable inertial LED brake light for bicycles that is really bright.
Using suction cups from Uncle Bezos and a piece of 1/8 x 3/4 aluminum bar stock, I made a very workable prototype with another to follow.
Very happy with the results !
File Type: jpg 3EB8EB26-B739-43E1-834C-E9B2D82B505F.jpg (26.3 KB, 79 views)
File Type: jpg BCF7F00A-22B8-4730-A77B-CEA95251E9D0.jpg (35.7 KB, 77 views)
File Type: jpg F24B5584-16B8-42B0-8D55-C6F43A5D84D4.jpg (64.6 KB, 79 views)
