Old 08-17-2022, 01:29 PM   #1
ChicagoBob
ChicagoBob's Avatar
Default Dreaded stuck timing gear nut
Well, here we are in August, and my car is disassembled. Although it was running well, I found several teeth missing from the timing gear, and disassembled the front of the engine to install a new one. However, there is apparently no force on earth that can remove the old cam nut. I've tried the M.A.C. tool (only about 1/4" deep, so wrenches, impact guns or breaker bars can't get a purchase), a giant crescent wrench (same problem), and a 3-lb hammer and cold chisel, and that nut hasn't budged. I've got the car in gear and a rag between the gears.
I'm out of ideas. Any suggestions?
ChicagoBob is offline   Reply With Quote
