Old 08-12-2022, 04:48 PM   #1
Dorf55
Default Show stopper
I have a 55 Fairlane with a warmed over 272 ( bored .60 over, small cam, four barrel carb). I show the car locally, will drive four or five miles to a show with no issues, when I arrive and its time to park (no power steering, three on the tree) and I have to back up and go forward a couple times and take my foot off the gas the car will dye, and I have to pump it for a minute or so and it will finely start. It will sometimes die at stoplights if I don't keep the RPM up.
I'm running stock fuel pump with the wiper inlet pugged off, (no wipers).
I think I need a different fuel pump.. if so what will fit my 272 ? want to stay with a mechanical pump.
Thanks
Dorf55 is offline   Reply With Quote
Old 08-12-2022, 05:07 PM   #2
KULTULZ
KULTULZ's Avatar
Arrow Re: Show stopper
Is carb balance and curb idle set correctly?
I would perform a pressure and volume test on the pump before buying a new one, especially the junk they sell now.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 08-12-2022, 05:09 PM   #3
scicala
scicala's Avatar
Default Re: Show stopper
It sounds like you just need to adjust the idle speed and mixture screws when it's warmed up.
If that doesn't cure it, maybe a vacuum leak ?
Sal
Old 08-12-2022, 05:11 PM   #4
scicala
scicala's Avatar
Sorry KULTULZ. I think we posted at the same time.
Sal
Old 08-12-2022, 05:19 PM   #5
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Show stopper
Originally Posted by scicala View Post
... maybe a vacuum leak ?
Sal
A VACUUM TEST GAUGE is your friend ...
Old 08-12-2022, 07:24 PM   #6
Dorf55
Thanks !
Old 08-12-2022, 07:29 PM   #7
KULTULZ
KULTULZ's Avatar
Sal
Ain't no problem as you have seniority here ...
Old 08-22-2022, 12:51 PM   #8
Lanny
Lanny's Avatar
It could be a worn out accelerator pump in the carb.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 08-22-2022, 01:47 PM   #9
poolplayer1
Well said Kultulz, about the subject of seniority. By the way, what is the normal Vacuum psi on this 272/292 motors.
poolplayer1 is offline   Reply With Quote
Old 08-22-2022, 04:58 PM   #10
KULTULZ
KULTULZ's Avatar
Talking Re: Show stopper
Well, tenure also and his personality is a lot more stable than mine ...
Here is a tutorial on manifold vacuum as it will vary from one engine to another, how modified and how much wear -
https://www.freeasestudyguides.com/e...cuum-test.html
Old 08-22-2022, 05:11 PM   #11
dmsfrr
dmsfrr's Avatar
... what is the normal Vacuum psi on this 272/292 motors.
On a stock engine normal is in the 19/20 inches of vacuum neighborhood; subject to wear, aftermarket parts, workmanship, regular maintenance, elevation, etc. etc.
dmsfrr is offline   Reply With Quote
Old 08-22-2022, 11:14 PM   #12
Daves55Sedan
Daves55Sedan's Avatar
So, you have a dual action pump with the vacuum ports not being used, right?
Then I hope you have metal tubing from the brass intake manifold fitting (located in front of the carb) to the rubber hose poked through the firewall to the vacuum windshield wipers. If the tubing has been removed from that brass fitting, it is a major vacuum leak.
If, the original vacuum tubing for the dual action pump is still there, but disconnected, it does NOT need to be plugged (assuming the vacuum diaphragm is useless). However, any vacuum tubing connected to the intake manifold that has openings plugged with a rubber vacuum cap should be checked at least once a year for cracks in the rubber especially at the end of the cap. If you squeeze the end of the rubber cap and see a crack, replace the cap with a new one and clamp it to the tubing with a small nylon cable tie pulled tight.
Not sure what it takes to pull the top off a 4-bbl carb like yours, but on the little 2-bbl carbs they had that year, it takes less than 5 minutes to pull the top off the carb so you can clean the fuel inlet needle with gumout spray. Look down at the bottom of the bowl. If there is sediment visible down there, wipe it out clean and install a new gas filter.
Daves55Sedan is offline   Reply With Quote
