Old 08-10-2022, 01:09 AM   #1
bmwboxerboy
Default Wrinkle Finish Paint
For my 1939 Ford Pickup interior door panels, does anyone have recommendations for paint to duplicate the original wrinkle finish? Like interior, I believe these were originally green.
I appreciate any feedback
Mark
bmwboxerboy is offline   Reply With Quote
Old 08-10-2022, 04:17 AM   #2
ronn
Default Re: Wrinkle Finish Paint
there are several "textured" paints on the market, that you may attempt to use. then respray with the correct color as a 2nd coat.this will take some practice first.
Old 08-10-2022, 06:40 AM   #3
FortyNiner
FortyNiner's Avatar
Rustoleum sells a hammer finish rattle can version.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 08-10-2022, 08:31 PM   #4
Lanny
Lanny's Avatar
Plasti-Kote is one brand that sells spray cans of Wrinkle Finish textured
paint in various colors.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 08-10-2022, 09:38 PM   #5
Clem Clement
Clem Clement's Avatar
My 39 pickkup doesn't seem to have any wrinkle paint
Clem Clement is offline   Reply With Quote
Old 08-11-2022, 06:43 AM   #6
Don
Don's Avatar
I have used a heat gun to help the wrinkle process along and hot sun works also
DON P
Don is offline   Reply With Quote
Old 08-11-2022, 08:51 PM   #7
1948F-1Pickup
1948F-1Pickup's Avatar
I’ll say. Most of the spray can versions of “wrinkle” finish require a bit of technique. Temperature of what you’re spraying and of the paint itself is important. As is the thickness of the coating you spray. Age of paint. Use of a heat gun to dry…. Etc. Etc.
1948F-1Pickup is offline   Reply With Quote
