Old 07-01-2022, 08:27 AM   #1
Eric Jensen
Default Front Leaf Spring
Need some advice.
Just took the front leaf spring apart on a 29 truck with not much tension (maybe an inch?). There is a total of 12 leafs! With the middle spring square on the ends - maybe a replacement? They appear to be in good shape with no cracks - although the center bolt broke inside while unscrewing.
How do I know if I should just replace the whole spring (rather not) or remove leafs, or add tension the leaves?
My plan was to clean them up, POR-15, Rustoleum Enamel top coat, then Slip Plate on the touching sides and screw back together
See picture.
Thanks - and Happy 4th!
Eric Jensen is offline   Reply With Quote
