Old 06-28-2022, 09:57 AM   #1
1936 cv sedan
Default 36 ford coil remote adapter
I like to keep my car as original as possible but I have been advised to bypass the stock coil and hook up a 6V remote away from the heat. It increases spark for starting. What are your thoughts?
1936 cv sedan is offline   Reply With Quote
Old 06-28-2022, 09:59 AM   #2
Kens 36
Kens 36's Avatar
Default Re: 36 ford coil remote adapter
My opinion? If you are having a problem, have Skip Haney in Punta Gorda Florida rebuild your coil. Those adapters and remote coils always seem to cause more problems than they fix.
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 06-28-2022, 10:04 AM   #3
Kube
Super Moderator
Kube's Avatar
Ken
Big time X2!
Old 06-28-2022, 10:42 AM   #4
rotorwrench
rotorwrench's Avatar
The adapters made for the helmet type distributors are notorious for warping under heat load. Most folks learn the hard way on those things then switch back to stock to get away from the problems associated with those adapters. Skip modernizes the old style coils to a level of reliability that they never had when new.
Old 06-28-2022, 05:02 PM   #5
Lawrie
Lawrie's Avatar
I had one of those adaptors on the 33 when we first got it, you only had to wash the tail light and it wouldn’t start, now it has a Skip’s coil and it goes every were.
Lawrie
Lawrie is offline   Reply With Quote
Old 06-28-2022, 09:20 PM   #6
VeryTangled
VeryTangled's Avatar
Um, find another source for advice? Lawrie made a good and funny comment.
When I see them, that plate, wire, and tin-can coil all signal to me that someone is not trying to be as original as possible.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 06-28-2022, 11:42 PM   #7
Tinker
Tinker's Avatar
They probably work okay. The reason coils fail is age more so then heat. Heat certainly makes the degeneration more apparent. Heat is part of age if you use it, (it generates and is effected more from internal heat, then external motor heat). A rewound coil will last you most likely the rest of your life. Less you are 20. Then buy two. Just my opinion.
If you are sticking with the points and old coil. Skip really is the way to go. Get one or two before you can't, in my thinking.
Old 06-29-2022, 07:58 AM   #8
1936 cv sedan
Thank you for your feedback. I have not finished rebuilding the engine yet so all parts will be new. I will reach out to Skip and get one of his. I prefer to stay original .
Old 06-29-2022, 02:29 PM   #9
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Originally Posted by kube View Post
big time x2!
x3 !@!!
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 06-30-2022, 03:22 PM   #10
36coupe
36coupe's Avatar
X4 yes
36coupe is offline   Reply With Quote
