Old 06-22-2022, 07:09 PM   #1
metro1
Default Self adjusting brake conversion
I don't know why I didn't of this before I just replaced all the brakes on my '59 Galaxie but is it worthwhile to go back and add self adjusters now? How much trouble is it? On a car that will not really be driven a lot how often will I have to adjust them anyway.
metro1 is offline   Reply With Quote
Old 06-22-2022, 07:37 PM   #2
Stephenorf
Stephenorf's Avatar
Default Re: Self adjusting brake conversion
I think I read somewhere that Ford had switched to self-adjusting brakes by 59.
Stephenorf is offline   Reply With Quote
Old 06-22-2022, 07:42 PM   #3
Ford Freak
Not very often, perhaps every few years. - F F
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 06-22-2022, 08:35 PM   #4
metro1
Not self adjusting on this car unless someone previously took it off.
Old 06-23-2022, 12:26 AM   #5
miker98038
miker98038's Avatar
I don’t know about 59, but there’s a part list out there to convert 55-56 birds to rear self adjusters. A 59 should be a 9”, so shouldn’t be a problem. Once the new shoes are seated, it shouldn’t be a big deal. If they were ground to fit the drums (another lost art) even less so.
miker98038 is offline   Reply With Quote
Old 06-23-2022, 01:03 PM   #6
KULTULZ
KULTULZ's Avatar
Arrow Re: Self adjusting brake conversion
MERCURY - 1957
EDSEL - 1958
LINCOLN - 1959
FORD - 1961
The 'Changeover Kit' requires modification(s) of the self-adjuster parts. I would avoid that method myself.
And then you would need later shoes that have the webs drilled for the self-adjuster hardware.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 06-23-2022, 01:23 PM   #7
bobss396
bobss396's Avatar
I left my '59 manual. They are not set up for self adjusters as the adjusting slot is in the front of the backing plate. Later self adjusters had slots towards the rear.
bobss396 is offline   Reply With Quote
Old 06-23-2022, 06:17 PM   #8
KULTULZ
KULTULZ's Avatar
It is (was) recommended in the 1956 OWNERS GUIDE every 5000 miles as an example.
IF the front has been converted to DISC and the rear not upgraded to self-adjust, the driver will not likely notice any decrease in braking performance (other than a lower pedal as wear continues) and the front disc will wear more rapidly, especially if a METERING VALVE is not used in the conversion.
File Type: jpg 1956 FORD Owners Manual - Maint Guide - Page27.jpg (54.5 KB, 7 views)
Old 06-24-2022, 02:15 AM   #9
evintho
evintho's Avatar
Cool Re: Self adjusting brake conversion
I put self adjusters on my '54. Not sure about '59 Galaxie but mine went on effortlessly. The only mod I had to make was to cut new access holes in the front backing plates for the star wheels. Original holes didn't line up.
https://www.fordbarn.com/forum/attachment.php?
attachmentid=492758&stc=1&d=1656054823
https://www.fordbarn.com/forum/attac...1&d=1656054905
evintho is offline   Reply With Quote
Old 06-24-2022, 09:51 AM   #10
KULTULZ
KULTULZ's Avatar
Question Re: Self adjusting brake conversion
Interesting. Did the rear carrier plates have the adjusting access holes in the correct positions?
What kit(s) did you use and did you have modify the hold-down pins at all? Does yours still have the shoe adjusting cams/eccentrics on the front brakes?
Old 06-24-2022, 12:28 PM   #11
evintho
evintho's Avatar
The access holes on the rear backing plates were about 1/4" off but still allowed access to the star wheels. The front brake shoes, hardware kit, studs and drums are for a '68 Mustang. Perfect fit. Everything bolted right on except for having to make the extra access hole for the star wheels in the '54 backing plates. Pretty common practice on '52-'54 Fords.
Self adjuster left side
Self adjuster right side
Hardware kit
Front brake drum
and BTW, here's the rear replacement drum for '52-'54 Ford stock rearends.
Comes off a '70 Ford Econoline van......
Rear replacement drum
Old 06-24-2022, 05:46 PM   #12
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Self adjusting brake conversion
That explains it. Good info to know!
Old 06-24-2022, 08:54 PM   #13
paul2748
paul2748's Avatar
I put self adjusters on my 56 Bird. While the numbers for a 59 sedan may be different (different size brakes) there was two mods that I had to make. The first is the odd shaped piece that holds the shoes at the top. It has to be thinner to account for the thickness of the adjuster cable eyelet. The second was the access to the star wheel on the LEFT side - both front and back. You have to make a second slot to access the star wheel. Not a big thing to do - just mark where it should be, drill a hole and elongate it with a tool like a Dremel. I made it the same size as factory so a regular plug will fit
To what extent the 59 sedan is different from a 56 TBird, I don't know. Didn't have to buy new shoes as the old ones had the correct holes.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-26-2022, 07:08 AM   #14
KULTULZ
KULTULZ's Avatar
... and BTW, here's the rear replacement drum for '52-'54 Ford stock rearends.
OK, I see where you guys are coming from now. It is do-able.
Being the OCD person that I am, I would want to go to later model(s) take-offs but the junk-yard days are gone.
Old 06-26-2022, 04:22 PM   #15
evintho
evintho's Avatar
I put self adjusters on my 56 Bird. The first is the odd shaped piece that holds the shoes at the top. It has to be thinner to account for the thickness of the adjuster cable eyelet. The second was the access to the star wheel on the LEFT side - both front and back. You have to make a second slot to access the star wheel. Not a big thing to do - just mark where it should be, drill a hole and elongate it with a tool like a Dremel. I made it the same size as factory so a regular plug will fit.
Paul is right! I forgot about the washer that holds the shoes at the top. Had to make those too. I used about 10ga sheet metal and cut 'em to shape.....
https://www.fordbarn.com/forum/attac...1&d=1656278471
