06-16-2022, 07:02 PM | #1 |
Front brakes
The front brakes on my Model A has a "lower clovis set up". As the brakes are applied, the operating pin pushes down, making the clovis pins move horizontally which push the shoes to the drum. I realize the normal usual system has a operating wedge but mine has a "clovis set up". Anyone familiar with what i have in my front brakes vs the usual operating wedge ? Thank you.
Please refer to photo below . DA1FFCE3-4995-424A-9522-34A65559CD88.jpg |
06-16-2022, 08:25 PM | #2 |
Re: Front brakes
I installed a set of these on my 1930 town Sedan in the 1960s. They worked well, as I recall. I believe I bought them from either Rick’s Model A Parts, or Warshawsky’s in Chicago. They were called ‘brake floaters’.
Jim |
06-16-2022, 09:56 PM | #3 |
Re: Front brakes
If the "floaters" worked Ok, I'm surprised that Henry didn't use that instead of the more costly wedge and rollers.
Joe B |
06-16-2022, 10:01 PM | #4 |
Re: Front brakes
Those were aftermarket accessories for better braking. They work well. Flathead Ted makes a modern version.
06-16-2022, 10:11 PM | #5 |
Re: Front brakes
THANK YOU JIM , JOE B AND FRANKLIN FOR YOUR REPLY . I APPRECIATE YOUR THOUGHTS . jack
06-17-2022, 05:04 AM | #6 |
Re: Front brakes
06-17-2022, 07:47 AM | #7 |
Re: Front brakes
I installed these in the 80's on my 29 PU when I could not get the wedge. They worked OK but added a squeak when I applied the brakes. The squeak served as a warning signal for anyone in hearing distance.
06-17-2022, 08:10 AM | #8 |
Re: Front brakes
Be careful with those. IF your brakes get way out of adjustment they can have too much movement and lock-up your brakes. FWIW
Paul in CT |
06-17-2022, 09:29 AM | #9 |
Re: Front brakes
THANK YOU DAVE, NKAMINAR AND PAUL. GREAT INFO AND APPRECIATE YOUR REPLIES . . . jack
06-17-2022, 10:10 AM | #10 |
Re: Front brakes
Yes, they go "over center" and lock your front brakes.
Ruth "Sometimes you really DO need to read the whole thread" |
06-17-2022, 10:45 AM | #11 | |
Re: Front brakes
06-17-2022, 11:09 AM | #12 |
Re: Front brakes
06-18-2022, 09:47 AM | #13 |
Re: Front brakes
Could be, one never knows who did what, when.
06-18-2022, 09:51 AM | #14 |
Re: Front brakes
A lot of people have some Clovis DNA in them. I guess it was party time when the two groups met.
06-18-2022, 10:32 AM | #15 |
Re: Front brakes
Are you a Clovis People if you live in Clovis, California? They don't look like they are "long extinct".
06-21-2022, 02:17 PM | #16 |
Re: Front brakes
I had a set of them on my 29 Tudor when i bought it. Brakes felt mushy. Went back to Henry's design. Brakes felt more solid and seem to stop quicker.
06-21-2022, 09:55 PM | #17 |
Re: Front brakes
RUTH and PIPEBNDR THANK YOU . I APPRECIATE YOUR INFO. jack
