Old 06-07-2022, 08:47 PM   #1
Fatheads4ever
Fatheads4ever's Avatar
Default Transmission goes 'boing'
Hi gents and others.. for decades my transmission has gone boing when changing direction especially to reverse. It happens when the clutch is released. A friend's truck does the same thing.
I've recently rebuilt the gearbox but it still does it. Can't tell if it's coming from the diff or gearbox.
Any ideas anyone?
Regards Kevin
Fatheads4ever is offline   Reply With Quote
Old 06-07-2022, 09:03 PM   #2
Zeke3
Zeke3's Avatar
Default Re: Transmission goes 'boing'
Kevin, I have a non-Ford car that had a squeak like noise that turned out to be the splined connection between the axle and a universal joint. I am thinking your noise might be the splined connector between the drive shaft and the pinion shaft at the differential. There was a picture on here not very long ago that showed excessive wear on a splined coupling. Good luck with your search.
Zeke3 is offline   Reply With Quote
Old 06-08-2022, 01:32 AM   #3
Graeme / New Zealand
Graeme / New Zealand's Avatar
Any ideas anyone?
Regards Kevin
Kevin you might find your answer here.
https://www.youtube.com/watch?v=uNsyQDmEopw
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 06-08-2022, 01:35 AM   #4
Fatheads4ever
Interesting.. there is a splined connection from the tail shaft of the gearbox to the universal. I think that coupling is lubed from the gearbox. I might change the gearbox oil from ep90 to 600 and pack the universal's internal spline with a hard grease.
Thank you for your feedback.
Old 06-08-2022, 06:46 AM   #5
Terry,OH
Terry,OH's Avatar
Is "boing" a tech term?? Maybe you can explain in more detail what is happening. Did you rebuild the shift mechanism? Is the transmission jumping out of gear?
Do NOT use 600 in your transmission. You can use 0-0 in the U-joint housing about 6 OZ. The U-joint does need lubrication, but it does not get it through the rear bearing. You can add lube through the speedometer turtle by removing from the torque tube.
Old 06-08-2022, 10:17 AM   #6
pistonbroke
Is the vehicle in question the 42 thru 47 pickup in your member sign on? If so I would check your slip joint at the front of the drive shaft and the pinion shaft for play. Tim
pistonbroke is offline   Reply With Quote
Old 06-08-2022, 05:37 PM   #7
Fatheads4ever
Hi Terry.. I installed new bearings, synchro cones, good synchro sleeve and replaced 2nd gear. Selectors are the same. It used to jump out of 2nd but not any more.
The boing noise sounds more like a bell. Only does it when changing direction. It did it before the rebuild..
Old 06-08-2022, 08:07 PM   #8
Fatheads4ever
Will do thanks Tim.
Old 06-08-2022, 09:47 PM   #9
Fatheads4ever
GB
Hahaha boing boing
Old 06-08-2022, 10:26 PM   #10
swedishsteel
my guess would be a u joint
swedishsteel is offline   Reply With Quote
