06-05-2022, 08:33 AM | #1 |
Zenith float
Was cleaning my carb yesterday and noticed the hinge tube on the float has broken loose, can it be repaired? It was running fine, maybe it just happened. Do I need to get another? Thanks
06-05-2022, 09:09 AM | #2 |
Re: Zenith float
A little solder - to hold will work
www.whidbeymodelaclub.com Last edited by Gary WA; 06-05-2022 at 11:29 AM. |
06-05-2022, 07:38 PM | #3 |
Re: Zenith float
A helper on these little jobs sometimes is a big benefit.
06-06-2022, 03:13 AM | #4 |
Re: Zenith float
I have notice some new repro ones are not soldered - just crimped
06-06-2022, 07:08 AM | #5 |
Re: Zenith float
Try to get the bracket exactly in the same position or you will not be able to get a good gas level adjustment. Use flux and lead based solder to keep the heat down. This is an easy repair. Ed
06-06-2022, 08:20 AM | #6 |
Re: Zenith float
