#1 |
Hello and welcome to Mart's Garage. In this video I investigate the running hot and coolant ejection problem on the 32 sedan.
Thanks to all who have been following the big inch flatty build and the entire Pendine series. Mart. https://youtu.be/J-2HV8k-kt4 |
#2 |
Mart,
You do good work figuring out what is wrong, when you have a problem! Great watching your videos! Thanks for taking the time to do these. Inspiration for sure! Regards, Chris
1932 AAB Truck 1953 Ford Jubilee 1965 Mercury Comet Caliente 1966 Ford F100 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
#3 |
Thanks Mart, appreciated the video very much. Thank you for sharing and your process of solving the problem.
Still smokin tires and cigars |
#4 |
Mart,
My preference are the BEST composite big bore gaskets and studs. A royal pain if a head requires removal for sure. Copper spray and immediate install. OMHO ! Charlie ny |
#5 |
Good show Mart, glad you got it figured.
#6 |
#7 |
As ALWAYS....great videos from Mart, for sure! But has anyone noticed how Mart always speaks so eloquently, yet the rest of us sound like a bunch of country bumpkins? Coop/AMERICAN . |
#8 |
Blimey I've never been called eloquent before..
Thanks for all the comments fellas. |
#9 | |
![]() GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
#10 |
I did not understand why you drilled a hole in the Thermostats.It would be nice to be able to check the temperature in each side of the engine. You did have several problems. Who head gaskets work the best for you? Do you push water on a hard pull? That the way I check my 35 Pickup. Overflow tank is a must I have found.I had my Radiator rodded out to be extra clean which is a must. I have 190 Thermostats in my Pickup which I like.I am running stock a 37 engine with inserts. Since 97 carb. Thanks for the film. I enjoyed it very much. Wish I was there.
