#1 |
The new tires I ordered for my ‘29 Tudor were delivered today. I think I might have selected the wrong size.
#2 |
No I think they’ll work
Just be sure they don’t rub the fenders! |
#3 |
Monster A?
#4 |
Rural mail carrier tires!
#5 |
So that's where my tires ended up, lost another set...
As Carroll Smith wrote; All Failures are Human in Origin. |
#6 |
#7 |
Are you going to mount them yourself? Could require a couple large tire irons.
Dan |
#8 |
Ordered New Tyres for my Ford Model A - Dean Lemoine |
#9 |
Naaa, they look fine !
#10 |
Might want to change your gearing also.
#11 |
I think they are a little too small. Return them for the next larger size!
#12 |
Remove the fenders and good to go. You may need a spotter to turn L/R.
#13 |
Be sure to soap up the bead and they'll slip right on!
#14 |
Finally got the tires on. The fronts rub “just a little.” It handles really well, but the speedometer reading seems to be off now. Suggestions?
#15 |
Speedometer/odometer likely will be out of calibration with these tires.
#16 |
But you only got four??? You should probably order a spare, just to be prudent...
#17 |
You have the makings for the 1st monster truck model A.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
