Old 05-06-2022, 08:07 AM   #1
Mart
Mart's Avatar
Default 2223 Pendine Prep 14. Big inch Flatty First Start and Drive! Yay!
Hello and welcome to Mart's Garage. In this video I am finally ready to start up the 286 cu in flatty. That's 3-3/8" bore and 4" stroke. I have a few issues to contend with along the way, but am able to take the car for an initial run. I then get a second run after addressing some issues.
I hope you find it interesting, it's another step in the right direction in getting the car ready for racing on the beach at Pendine.
Thanks to all who have been following the big inch flatty build and the Pendine Prep series.
Mart.
https://youtu.be/r2P0gkn5ieo
Old 05-06-2022, 09:43 AM   #2
deuce5wndw
deuce5wndw's Avatar
Default Re: 2223 Pendine Prep 14. Big inch Flatty First Start and Drive! Yay!
Congratulations Mart! A job well done and thanks for taking us along!
Regards, Dale.
deuce5wndw is offline   Reply With Quote
Old 05-06-2022, 12:32 PM   #3
drolston
drolston's Avatar
Nice runs. Love the sound of a big inch flathead.
I had the same problem with engine dying when coming to a stop. I turned out to be lack of enough return spring on the secondaries on the 3x2 intake. It left the secondaries open a bit, amounting to a big vacuum leak. That is not your setup but it might be worth checking carb synchronization and any slack or friction in the linkage to the front carb.
Thanks for the show.
Old 05-06-2022, 12:41 PM   #4
sugarmaker
sugarmaker's Avatar
Mart,
Thanks for taking us along on your journeys with the rebuilt flathead! Very enjoyable.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
1965 Mercury Comet Caliente
1966 Ford F100
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 05-06-2022, 03:30 PM   #5
done4
done4's Avatar
Send a message via Yahoo to done4
Thanks Mart! Super cool it all turned out for all your hard work you invested. I have to admit I still freak out on the ride alongs, I wouldn’t do well on your roads. Thanks agin Mart.
Still smokin tires and cigars
done4 is offline   Reply With Quote
Old 05-06-2022, 06:26 PM   #6
corvette8n
corvette8n's Avatar
Glad you found the interference between the oil line and the brake pedal. I did a similar thing last year when I put a new pipe from the header to the muffler, I went to back the car out of the garage but the clutch hit the pipe, I had to loosen the clamps and rotate the pipe to clear.
Old 05-12-2022, 11:26 AM   #7
Als48
Good job as usual, Mart. I loved the driving video. I've forgotten what your rear end ratio is in the '32. It seems very responsive, as if it's geared low. Maybe just my bad hearing.
Al Hook
Als48 is offline   Reply With Quote
Old 05-12-2022, 01:35 PM   #8
Mart
Mart's Avatar
Hi Al. 3.78s in the Sedan. Glad you enjoyed the video.
Just been thrashing on the car. Off to Pendine in the morning.
