Old 05-05-2022, 07:54 PM   #1
alanwoodieman
Default 8ba crank in A block
can this be done?? difficulties going to encounter?
alanwoodieman is offline   Reply With Quote
Old 05-05-2022, 11:11 PM   #2
Pete
Default Re: 8ba crank in A block
A 90 degree crank has been put in an A block before. All that can be said is, it ran.
Old 05-06-2022, 10:05 AM   #3
Bored&Stroked
Bored&Stroked's Avatar
Are you taking about an early 221 CI flathead that has a big letter 'A' on the heads? Usually about a 39-41 vintage?
Old 05-06-2022, 11:09 AM   #4
tubman
tubman's Avatar
Or, in the alternative, a Model "A" block.
(I added this because I was initially confused by Dale's post until I thought about it some.)
Old 05-06-2022, 12:55 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Me too! My head was beginning to hurt trying to imagine all sorts of things (and reasons) to put one in a "Model A" block! Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 05-06-2022, 01:13 PM   #6
Bob C
I'm glad I wasn't the only one confused.
Old 05-06-2022, 03:31 PM   #7
bobH
I'm also on the 'confused list'... And, really curious. Wishing Pete would elaborate a little, if indeed, an 8ba crank in an A block (and, I mean Model A). And, is this what Alan had in mind?
bobH is offline   Reply With Quote
Old 05-06-2022, 04:15 PM   #8
jimTN
I think a lot of relative new comers may think of a 59AB as a A block when there are several possibilities to describe a flathead. To begin with, in the Ford and Merc line they are either 221ci 21 stud or or 221ci and 239ci. 24stud blocks. To my knowledge the 24stud mains are the same diameter up to 53.
jimTN is offline   Reply With Quote
Old 05-06-2022, 06:00 PM   #9
alanwoodieman
yes I am referring to a 39/41 Ford V8 block commonly call an A block not a model a 4 cylinder as has been booted around
Old 05-06-2022, 08:08 PM   #10
flatjack9
flatjack9's Avatar
It will go in with no problem. You'll have to bore the engine to 3 3/16 to fit the big end of the rod down the hole.
Old 05-06-2022, 09:57 PM   #11
Bored&Stroked
In my mind, it was not called an 'A' block - more along the line that it is a 221 CI Ford engine with a 3 1/16 bore - with a variety of heads (some of which had the big letter 'A' on them). There were other heads that did not . . .
Old 05-06-2022, 09:59 PM   #12
Bored&Stroked
Also, you will need to change the rear pot metal slinger/seal plates - to the later ones with the rope seals) - as the 39-41 blocks used an earlier slinger/labyrinth type of seal.
Old 05-06-2022, 10:27 PM   #13
alanwoodieman
have done this before but not in a long time, still have the pot metal slinger from joblot's reproductions. just need any know reminder, yes block was bore to 3 3/16. bored and stroked--sorry your mind id different than mine, as I always referred to this as an A block
Old 05-07-2022, 07:46 AM   #14
Elmo Rodge
Elmo Rodge's Avatar
Which main bearings will he use?
Wayno
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
Old 05-07-2022, 08:17 AM   #15
Tim Ayers
I thought mains follow the block, not the crank. Could be wrong.
Old 05-07-2022, 09:40 AM   #16
flatjack9
flatjack9's Avatar
Mains do follow the block
Old 05-07-2022, 10:35 AM   #17
DavidG
DavidG's Avatar
"Commonly"? Where is a 59A block referred to commonly as an 'A' block? But what the heck, I've no doubt missed lots of things during my 67+ years in the hobby.
Old 05-07-2022, 11:40 AM   #18
rotorwrench
rotorwrench's Avatar
81A for 38-40 221 with 24 studs. 99 or 99A for early 239. The 11A block was when they changed the castings. The 59 series also included the replacement 41A for 221 engines but many have the 59 casting mark as well.
The Big A heads were just the 81A heads. Prewar 24-stud 221 block pretty well says it all. When I think A and block put together, I think Model A 200 CID 4-cylinder block.
Old 05-07-2022, 11:54 AM   #19
cas3
delete
Old 05-07-2022, 11:54 AM   #20
alanwoodieman
you guys need a new hobby
