04-25-2022, 08:50 PM | #1 |
What is the best way of removing a stuck brake pedal shaft collar on '31 Model A?
04-25-2022, 09:05 PM | #2 |
Re: What is the best way of removing a stuck brake pedal shaft collar on '31 Model A?
A lot of penetrant oil and a bigger hammer!
04-25-2022, 09:25 PM | #3 |
Penetrant oil yes, if no go then, next step is heating with a torch and cooling to room temp a few times, when it is still hot push a candle into the joint and the wax can work as a lubricant, if no go gently cut each side almost through and break it with a chisel. It is a cheap part don't worry if you need to buy a new one,
04-26-2022, 10:02 AM | #4 |
First, remove the pin that's holding the collar.
04-26-2022, 11:14 AM | #5 |
04-26-2022, 12:04 PM | #6 |
