Old 04-24-2022, 02:48 PM   #1
russcc
Default Ignition information
Just got back from EV8 swap in Fitchburg MA. Cool & windy, a lot of vendors and people. Lots of very happy & smiling faces as this is an excellent meet which was really missed the last 2 years.
Here is what I heard from a local guy. He had been running a Mallory electronic ignition on his 274 flathead w/dual carbs, heads & Isky Max cam. The module failed so he called MSD that bought out Mallory to get another one. No modules. He asked MSD if they were supporting Mallory, "No". MSD apparently bought the competition. Speedway had a couple left, so he got one from them. That one failed. He bought the Stromberg ignition, and was informed that their module was made by Petronix. He installed it on his engine and was very pleased with it for the following reasons; 1. He could not get the Mallory to idle below 850 by adjusting the 2 carbs and the timing, and the Stromberg ran at 675. He also noted it started quicker, and had more power, apparently from a stronger spark. Be interested in other shared experiences
russcc is offline   Reply With Quote
Old 04-24-2022, 03:42 PM   #2
1948F-1Pickup
1948F-1Pickup's Avatar
Default Re: Ignition information
MSD has a fairly significant history of either actively eliminating the competition or contributing/assisting in the demise of other providers. (Hays and Jacobs come to mind being more recent in this trend)
1948F-1Pickup is offline   Reply With Quote
Old 04-29-2022, 02:49 PM   #3
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Eating modules = too much current !!! Too much current ALWAYS low resistance coil !!!!!!! Pretty simple these aftermarket coils just will not stand a low resistance coil!!!!!!!!
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 04-29-2022, 03:32 PM   #4
Flathead
Flathead's Avatar
Points will eliminate module problems permanently. Yes I'm an old fart but I can make points work!
Flathead is offline   Reply With Quote
Old 04-29-2022, 05:21 PM   #5
19Fordy
19Fordy's Avatar
Bubba, Did you mean to say "aftermarket modules" just won't stand a low resistance coil?
I recall you have posted many valuable threads about this.
