04-18-2022, 05:32 PM | #1 |
1947 front panhard(track) bar bushings?
Looking for a source for these new. I’ve called a couple of the big guys like Drake and Carpenter. Have not been able to find them yet.
Would shock bushings work for this? And if so does anyone have a source for just shock bushings? |
04-18-2022, 05:41 PM | #2 |
Re: 1947 front panhard(track) bar bushings?
if its the same as a 39 shock bushes work fine had the same problem [not listed] trip to local parts bloke sorted it out [3 years ago still good so no worries ]
04-18-2022, 06:47 PM | #3 |
Local parts stores have the rubber bushings or the nylon type. They should be able to find you some by the OD,ID and width.
04-18-2022, 07:59 PM | #4 |
A company called "Energy Suspension Parts" has all sorts of sway bar and other bushings.
04-18-2022, 09:41 PM | #5 |
I always used shock bushings from parts store.
04-19-2022, 09:48 AM | #6 |
04-20-2022, 11:45 AM | #7 |
I have a '47-48 panhard/track bar, very similar to the bar you have, on the rear of my '36, I have always used rubber shock mount bushings.
Bill.... 36 5 win cpe |
