Old 04-17-2022, 02:56 PM   #1
highbeams
highbeams's Avatar
Default wedges
My '36 half-ton had 3 wedges between cab and frame per side . . .
(per side, to be placed atop each other for frontal-cab height adjustment.)
So minimal - the adjustment! Reason? Thank you.
highbeams is offline   Reply With Quote
Old 04-17-2022, 03:00 PM   #2
Don
Don's Avatar
Default Re: wedges
Probably to get hood to align with fenders ,this is normal for some of the cars I’ve done,,
DON P
Don is offline   Reply With Quote
Old 04-17-2022, 07:44 PM   #3
highbeams
highbeams's Avatar
Default Re: wedges
Thank you, Don.
Old 04-17-2022, 07:45 PM   #4
highbeams
highbeams's Avatar
Default Re: wedges
Thank you, Don.
Old 04-18-2022, 06:36 AM   #5
ms fowler
Default Re: wedges
Were these wedges all the same size? Are there "standard" measurements, or are they just cut to fit?
ms fowler is offline   Reply With Quote
Old 04-18-2022, 10:15 PM   #6
highbeams
highbeams's Avatar
Default Re: wedges
All the same size, notches, so they fit together when adjusting them back and forth; i.e., for height?. One-inch wide. one by one +- (near the frontal cab bolts.
It's been 20 yrs+- ago. The shop pulled the cab (for frame painting) and there they were!(unstacked but very close together on top of the frame .) After painting, I put 'em back, stacked, same each side; viewed as the cab was bolted tight.
I can't imagine the difference that they would make, for whatever their purpose, but they were there for a reason, obviously. Truck is 150 mi east, but still on the road!
Hopefully someone has some info. Got me hangin'.
Old 04-18-2022, 11:29 PM   #7
nelsb01
nelsb01's Avatar
Default Re: wedges
Does your cab have the wooden platforms that were there when assembled?
nelsb01 is offline   Reply With Quote
Old 04-19-2022, 05:18 AM   #8
ms fowler
Default Re: wedges
Thank you
