Old 03-28-2022, 03:33 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Softening rock hard rubber
I've watched all of the U-Tube videos and read/heard all of the sales pitches of various products and am understandably thoroughly confused, which at my age ain't unusual. What have YOU used and with what short/long term results?
Old 03-28-2022, 04:02 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Softening rock hard rubber
Counselor....Sometimes, you have to be ready to accept the fact that you just CAN'T make chicken salad out of chicken dookie! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-28-2022, 04:07 PM   #3
Lawson Cox
Lawson Cox's Avatar
My Daddy always told me "Can't never did anything". He was a wise man. (Picture a laughing emoji here)
Old 03-28-2022, 04:13 PM   #4
Kube
Super Moderator
Kube's Avatar
Soaking in automatic transmission fluid works occasionally.
Old 03-28-2022, 04:30 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
Back in the time when we used to use gasoline as a lubricant to sand lacquer
color coats prior to buffing and polishing, rubber squeegees were used as part of the process.
If you left a squeegee in a bucket of gas overnight, the next day the squeegee was like a limp noodle.
Old 03-28-2022, 04:38 PM   #6
Lawson Cox
Lawson Cox's Avatar
Do you recall if the squeegee returned to "normal" after it "dried out"? I'll have to give that a shot. I've got to drain the tank on Apatchy anyhow, so I'll give it a shot.
Old 03-28-2022, 05:56 PM   #7
51 MERC-CT
51 MERC-CT's Avatar
The squeegees were, after soaking, rendered useless for the purpose but
as I recall remained softer than they originally were.
Old 03-28-2022, 06:10 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Picture a frowning guy who CAN'T post pictures, here.
DD
T5 W/TORQUE TUBE
Old 03-28-2022, 08:17 PM   #9
Lawson Cox
Lawson Cox's Avatar
I have just been trying to follow your lengthy dissertation to me about posting pictures, DD. 'Nuff said.
Old 03-28-2022, 08:47 PM   #10
ford38v8
ford38v8's Avatar
It must be remembered that any and all of the products mentioned in this thread are solvents, and as such, will break down the composition of rubber as manufactured. In that less than stable condition, rubber becomes soft and gummy. Some solvents are better than others for use with rubber. The rubber industry uses toluene, which freshens up cured rubber that is to be rebonded, such as tires with recaps. If to be bonded, heat and pressure is used. If used only to freshen the surface, the end result will initially appear and feel as new, but is in fact a degradation of the original surface.
Alan
Old 03-28-2022, 09:16 PM   #11
petehoovie
petehoovie's Avatar
Some good tips here > https://homeguides.sfgate.com/chemic...-13414995.html
Old 03-28-2022, 10:07 PM   #12
Pete
What Alan said in post #10.
Common bleach (sodium hypochlorite) works sometimes. We used to soak our qualifying tires for the midget in it before it was illegal.
Old 03-28-2022, 11:32 PM   #13
cas3
We used to use brake fluid to make tires blacker, not sure what it does to rubber though
Old 03-29-2022, 04:22 AM   #14
richard crow
have you ever put a brake cylinder cup in a gasoline bucket. next day as big as a jar cover
richard crow is offline   Reply With Quote
Old 03-29-2022, 07:58 AM   #15
jayvee34
jayvee34's Avatar
Best analogy yet. LOL
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 03-29-2022, 12:41 PM   #16
oldford2
oldford2's Avatar
Just the reverse:
If you have something soft, how do you get it hard.
John
oldford2 is offline   Reply With Quote
Old 03-29-2022, 01:17 PM   #17
Karl Wescott
Karl Wescott's Avatar
Lawson
Make an accurate sketch of what you need to show. Base od, Height, od 1/4 up from base, od 1/2 up from base, od 2/3 up from base, id and height of hole you need for mounting. Post, pm, or email.
I will make a 3D model and print in hard plastic. You should be able to paint it flat black and epoxy onto your pump and make it look as good as new yet "for display purposes only".
Karl Wescott is offline   Reply With Quote
Old 03-29-2022, 01:50 PM   #18
Bruce_MO
I've heard that Model A guys will soak NOS radiator hoses in boiling water to soften them to be able to install them. Doesn't mean they won't leak, though.
Bruce_MO is offline   Reply With Quote
Old 03-29-2022, 03:09 PM   #19
Lawson Cox
Lawson Cox's Avatar
Originally Posted by Karl Wescott View Post
Lawson
Thanks Karl. I will do that. Give me a few days. I am deep into finding out what my problem is with Apatchy. My Avatar. Trash in the gas. I have drained the tank and filtered the gas through a pillow case. Pretty good bit of black stuff. This is a relatively new Drake reproduction tank. I'm going to put the filtered gas back in the tank, slosh it around good and do the same all over again till it comes out clean. Charlie NY has my carb and fuel pump, cleaning them out. I am replacing all rubber gas lines with ethanol safe hoses and new filters at the electric pump, fuel pump and carburetor. It is challenging my 90 year old body, but I WILL[ get it done and post the results. Check your PMs as well. Lawson
Old 03-30-2022, 09:30 AM   #20
JM 35 Sedan
JM 35 Sedan's Avatar
DD
Or picture a guy with a soft noodle in one hand and a piece of hard rubber in the other hand, who still can't post a picture
John
