03-26-2022, 08:20 PM | #1 |
Rear Axle Parts
I have a 1963 Ford Galaxie and need rear end axle bearings and seals. Where do you folks order your parts from. I’m in Ontario Canada and cannot find anyone local. I don’t mind ordering from the U.S.
Thanks |
03-26-2022, 09:26 PM | #2 |
Re: Rear Axle Parts
Try Concours Auto Parts in Carson City, NV
I use them for parts for my '54 Ranch Wagon. Good people to deal with. They have a catalogue for your year and it does list rear axle parts. https://www.parts123.com/parts123/yb...1~cadeficb~~10
Making the simple complicated for over 30 years. |
03-26-2022, 09:47 PM | #3 | |
Re: Rear Axle Parts
I’ll check em out. |
03-27-2022, 08:42 AM | #4 |
Re: Rear Axle Parts
Concours is a good choice, as is C & G Ford Car Parts. I have had pleasurable dealings w/both. - F F
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
03-28-2022, 12:38 PM | #5 |
Re: Rear Axle Parts
Try a NAPA store. My local store stocks the stuff, the bearing is: BRG RW207 CCRA and the seal is NOS 15142
03-28-2022, 08:15 PM | #6 |
Location: North Warrandyte, Melbourne,Victoria, Australia
Re: Rear Axle Parts
As they DON'T&WON'T leak, BUT you have to &must 1st soak them overnight in light engine oil. The problem with modern neoprene rubber lipped seals is that when they get a slight " nick" in the lip they lose lubrication then get hard &can &do leave wear on the axle shaft negating use of a aluminium "speedie sleeve".In our expereince whenever a customer complains about a leak it's because the NON-original seals have gone hard&the owner/or mechanic hasn't been able to source original or aftermarket leather lipped oil seals.The part numbers you need, require want is:FORD B7A1177B/B7A1177B1/C7UW1177D, NATIONAL 6939 |
04-01-2022, 07:10 AM | #7 |
Re: Rear Axle Parts
I put in my axle tube seals with a piece of leftover aluminum rod and buggered one. It leaked after about 2 years. I sprung for a Harbor Fright seal install kit, did it right.
My parts came from NAPA the 1st round. They soaked me for the bearing press charge, the new seals I got on eBay. |
