03-15-2022, 10:05 AM | #1 |
Tobin Arp Line Bore Machine
City:
Templeton
State:
Ca
Price:
In ad
Tobin Arp TA-14 line bore machine, set up exclusively for Model A/B block line bore & capable of line boring cam journals too. Sunnen custom built CH-1800 hone bar for Model A Block with wet honing stand. Custom made Model A/B block alignment fixtures, custom precision ground false cam & 1.125 setting bar, custom made precision fixtures to set line bore center to factory specs. Thrust washer cutter: Bridgeport Right Angle Drive attachment & 2.25 new way cutter for cutting thrust washers on a Bridgeport mill. Several set up micrometers as well as custom precision cutter depth dial micrometer. Second LBM-Kwikway w/60” bar, ford rails, comes with 4 bridges & tooling. Large inventory of Model A blocks & cranks Custom made 110v Hot tank for model a block. Selling as a complete package. I am creating a catalog of the equipment and putting photos together. Send a PM with your email & contact info if you are interested to receive details when they are available this spring.
Tim Downtown, Ca Last edited by CA Victoria; 03-15-2022 at 01:52 PM. |
