03-09-2022, 12:52 PM | #1 |
Diagram of rear brake springs and pin orientation?
Can anyone point me to a good diagram ( or picture - I seem to recall Tom Wesenberg posted one ) of rear brake spring positions and pin orientation for rear service and emergency brakes .
03-09-2022, 01:17 PM | #2 |
Re: Diagram of rear brake springs and pin orientation?
03-09-2022, 05:28 PM | #3 |
I assume you are looking for the location of the brake springs inside the rear hubs. Attached are 2 Ford drawings one shows the emergency brake assembly and springs while the other shows the service brake assembly and springs.
03-10-2022, 03:54 AM | #4 |
Thanks Bruceincam and Frank55a. I always need a pic when reassembling brakes! - never remember which hole the springs go in, or which way for the pins .....pictures now clearly show them.
Service brake all pins have heads on the inside ( cotters on the outside) Emergency brake all heads on the outside ( cotters on the inside ). Thank you Last edited by johnbuckley; 03-10-2022 at 06:35 AM. |
03-10-2022, 07:13 AM | #5 |
I have found it helpful to take a picture with my phone camera before I disassemble, then if I get stuck putting together I have a reference photo.
03-10-2022, 09:12 AM | #6 |
03-11-2022, 06:22 AM | #7 | |
Q: what am i missing as far as an "assembly diagram?" do i have to have an account? |
03-11-2022, 09:45 AM | #8 | |
There is a lot of usful info in Bratton's catalog, for example bolts sizes and threads, exploded diagrams of assemblies, torque specs. |
