Old 03-04-2022, 11:53 PM   #1
Pandersen33
Pandersen33's Avatar
Default Early master cylinder ID
Anyone recognize this master cylinder? Looking to replace it as its obviously leaking. Its a 2-bolt so a little different from the genaric juice-brake masters. I just need something that will fit
Thanks.
File Type: jpeg E37E067F-1AB6-4F61-85A5-2AC45F003C54.jpeg (118.3 KB, 87 views)
File Type: jpeg 45BE1A48-68F6-4333-B5D6-1EF9BE17539F.jpeg (86.9 KB, 62 views)
File Type: jpeg 47D553D4-7A6C-4C84-8D9D-BF39DE2E7ABA.jpeg (120.1 KB, 63 views)
Pandersen33 is offline   Reply With Quote
Old 03-05-2022, 12:03 AM   #2
Tinker
Tinker's Avatar
Default Re: Early master cylinder ID
deleted... now there is pictures... No clue personally.
Old 03-05-2022, 12:06 AM   #3
Pandersen33
Pics attached now
Old 03-05-2022, 01:29 AM   #4
mobileparts
I have it brand new --- but not with the screw type lid, but with a standard bale wire lid ...
Call me --- 516 - 485 - 1935.... Long Island, New York.... Craig....
mobileparts is offline   Reply With Quote
Old 03-05-2022, 03:32 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
Thanks.
Your M/C 'LOOKS' like the one BELOW. But rather than "just needing something that will fit", you should be more-aware of the diameter of the bore, with an inclination toward matching the bores. Using a M/C with as little as 1/16" DIFFERENCE in diameter of the bore can considerably alter the feel, as well as the amount of force required to push on the brake pedal to match the performance of the M/C that you now have.
Below is the M/C that I found that appears like yours. Click the link BELOW for information on that particular M/C. DD
https://www.ebay.com/itm/38475385959...epid=236499040
Click Links Below __
T5 W/TORQUE TUBE
Old 03-05-2022, 09:04 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
Not an early master but looks like a GM dual master that someone cobbled up for use as a single hanging master on early firewall.
Old 03-05-2022, 09:25 AM   #7
Mart
Mart's Avatar
I think it is plumbed as a dual. Note thin pipe coming from banjo on forward fitting.
Old 03-05-2022, 11:48 AM   #8
cas3
Fire wall should also have some reinforcing on the inside or my guess is that will eventually crack as they are not thick enough on its own
cas3 is online now   Reply With Quote
Old 03-05-2022, 12:00 PM   #9
1942deluxe
1942deluxe's Avatar
51 MERC-T , I think you are correct. Looks identical to the 67 Camero master cylinder my brother used on his 1957 Nomad.
Old 03-05-2022, 12:39 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
That AC Delco "18M1988" part number crosses to a RAYBESTOS "36233", available in the link BELOW. The link below shows a substantial SAVINGS (about a $33 SAVINGS) for the same M/C.
https://www.partsgeek.com/bpb4ldd-ch...10070301008005
This particular M/C has a 25.4mm DIAMETER Bore (1"). DD
T5 W/TORQUE TUBE
Old 03-05-2022, 02:00 PM   #11
51 MERC-CT
51 MERC-CT's Avatar
Believe you are correct, spotted the tube on closer inspection.
Old 03-05-2022, 02:29 PM   #12
51 MERC-CT
51 MERC-CT's Avatar
Looks like a bracket assy. is bolted to the firewall.
Old 03-05-2022, 02:51 PM   #13
cas3
OPPS ! guess I need to look at all the pictures before I open my big mouth ! thanks 51 merc
Old 03-05-2022, 07:44 PM   #14
Pandersen33
Thanks! Should have known based on some of the other parts that it wouldnt have been a ford MC.
