Old 02-25-2022, 09:12 PM   #1
FRANK PKNY
FRANK PKNY's Avatar
Default identify a 50 block
I'm building a 59-engine bored .100 with a 4" stroke Scat crank. I noticed the block is factory relieved. I think it was a truck block. I also found this number cast into the block. I have never seen one with this type of marking? look at the photo does the prefix C indicate a Canadian built engine?
FRANK PKNY is offline   Reply With Quote
Old 02-25-2022, 10:11 PM   #2
ford38v8
ford38v8's Avatar
Default Re: identify a 50 block
Your block is a 59 series of American manufacture between 1945 and 1948. The other letters and numbers near the large 59 are of no significance in identifying the block.
Alan
Old 02-25-2022, 10:49 PM   #3
mercman from oz
mercman from oz's Avatar
Your block is a 59 series of American manufacture between 1945 and 1948 - ford38v8
Old 02-26-2022, 08:23 AM   #4
FRANK PKNY
FRANK PKNY's Avatar
Thanks it's a factory relieved block, I thought the C possibly meant made in Canada ? I have three other 50 blocks and none of them have that prefix and number on them. 59A block does not have that on it? Frank
Old 02-26-2022, 12:25 PM   #5
deuce_roadster
deuce_roadster's Avatar
As stated above, blocks with 59 on them are not 50 blocks. 49-53 blocks have the bell housing that bolts to the block, not cast as part of the block like the 59 series units.
Old 02-26-2022, 03:34 PM   #6
bbrocksr
The pipe plug location in the upper left corner of the picture looks a little different than the 59 A & l s that I have had.
Bill
bbrocksr is offline   Reply With Quote
