Old 02-18-2022, 06:52 PM   #1
36coupe
36coupe's Avatar
Default Rear shock mount for a banjo rear
Will this shock mount work with a 37 rear?
If yes I only have one and would like to find one for the other side.
File Type: jpg 168B29DD-3C40-4B88-B53B-2DFDE952E7E7.jpg (40.5 KB, 485 views)
File Type: jpg 3F7AD6F8-45BC-4BD6-AEB7-759FDBE467F1.jpg (36.6 KB, 13 views)
36coupe is offline   Reply With Quote
Old 02-18-2022, 09:01 PM   #2
bbrocksr
Default Re: Rear shock mount for a banjo rear
Yes, They are stock on 48 Fords.
Bill
bbrocksr is offline   Reply With Quote
Old 02-18-2022, 09:53 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Well, good luck because I BELIEVE that one pictured is a LEFT-side piece. If that's true, you need to be lucky enough to find a "RIGHTY" to match that lone-LEFTY. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-19-2022, 07:40 AM   #4
36coupe
36coupe's Avatar
Yeah, I don’t expect to find one. I’ll keep it for ever and then it will be someone else’s problem some day. I also have 2 mounts for a 41 stabilizer bar, one side only, one year only.
Old 02-19-2022, 09:54 AM   #5
blucar
blucar's Avatar
As I recall, Ford went to tube shocks on the rear of '47-48 Ford and Merc's. The shock mounts bolt to the back side of the brake backing plate, using two long bolts in lieu of the stock short bolts.
Pix attached of the tube shock conversion on the rear of my '36, which has a '48 Columbia.
Bill.... 36 5 win cpe
Old 02-19-2022, 10:06 AM   #6
deuce lover
deuce lover's Avatar
Pure Hot Rods make them new.$129 a pr.I have seen them in the HAMB classifieds.Here is the link
https://www.jalopyjournal.com/forum/...ounts.1241485/
deuce lover is offline   Reply With Quote
Old 02-19-2022, 11:33 AM   #7
bobH
Check the length... Those ones that Sheldon referenced are advertised as longer, for use with lowered cars (I think). Seem like 'somewhere' I've seen others being made, but can't remember details. On the subject of the stock 46-48 brackets, like you've shown, I would speculate that it would be easy to locate those. I'm thinking of 46-48 rear ends that I've junked, and the rear ends that I've seen (few) have had those brackets. Early Ford Store, San Dimas, would be at least one place to ask. Or, someone on here, or hamb, surely has one of those rear ends 'out back'. Obviously, opinion.
bobH is offline   Reply With Quote
Old 02-19-2022, 12:13 PM   #8
cas3
I believe the original ford items were two different lengths. Folks would cut them to match. Someone on the hamb is making them new, that match, sorry I forget where to get them also.
Old 02-19-2022, 12:28 PM   #9
deuce lover
Look at post #6.Click on the link
Old 02-19-2022, 01:47 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
Sorry that I forgot to answer your question. YES...they will fit your '37 rear, as that outboard end of axle is identical mounting. DD
T5 W/TORQUE TUBE
Old 02-19-2022, 01:49 PM   #11
Tim Ayers
Correct. I forget which side, but one is longer.
Old 02-19-2022, 01:55 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
You know, I'm just now noticing that there are apparently TWO different versions of these arms in existence. The SINGLE version you have is a "51A-18165", whereas another pair I found shows different Ford part numbers ...."51A-18195" and "51A-18194".
Your Bracket
It can also be noted with the PAIR of brackets that one bracket is longer than the other, apparently hanging down lower in relation to the rear end just like "cas3" noted. Just more interesting Ford facts. DD
The PAIR of Brackets
T5 W/TORQUE TUBE
Old 02-19-2022, 07:43 PM   #13
36coupe
36coupe's Avatar
What would the reason be to have one longer than the other?
Old 02-20-2022, 09:59 AM   #14
rotorwrench
rotorwrench's Avatar
It was likely clearance issues. A rear panhard/track bar installation would make a difference.
Old 02-20-2022, 10:12 AM   #15
36coupe
36coupe's Avatar
Okay that makes sense.
Old 02-20-2022, 10:42 AM   #16
terry
I got a tube shock kit for the rear of my '36 several years back...so far so good. It was from C&G parts. Maybe they have them for37's as well. Terry
terry is offline   Reply With Quote
Old 02-20-2022, 11:12 AM   #17
TJ
TJ's Avatar
According to their catalog C and G still carries the rear shock kit.
Old 02-20-2022, 11:21 AM   #18
rottenron36
rottenron36's Avatar
I tried every way possible to get those to work on my 36 pickup. they don' fit. The way the bones are attached are different on a 36 rear and 46-48 rear. Plus, where they bolt on is different. Something was always in the way. Ron
rottenron36 is offline   Reply With Quote
Old 02-20-2022, 12:15 PM   #19
Ol' Ron
Ol' Ron's Avatar
I like to use the GM shocks from the 70s Camaros etc. and this lower mount works well. However you have to mak an adapter for the upper mount. Quite simple. These shocks ar 30/70 and made for your weight vehicle. Giving a nice ride, Not very expensive either.
Gramps
Old 02-20-2022, 12:57 PM   #20
V8COOPMAN
V8COOPMAN's Avatar
Just beware of the shock angle that you end-up with, as the GREATER the angle (as seen with the '40 Ford shown below), the less-effective the shock's dampening will be. The thing to remember with this example is that a '37 and a '40 both have essentially the same chassis AND rear end dimensions.
Ideally, the farther INBOARD that the BOTTOM of the shock mounts on the axle, and the farther OUTBOARD that the TOP of the shock mounts will make for a more-efficient shock angle. DD
T5 W/TORQUE TUBE
