02-10-2022, 12:53 PM | #1 |
Rear axles?????
Guys, looking to rebuild my a rear end sometime this year. Can NOS axles still be had? Are the newly made axles worth buying? Just collecting parts for now, need some sound advice.
Thanks for your thoughts |
02-10-2022, 01:13 PM | #2 |
Re: Rear axles?????
I just recently rebuilt my rear axle and it was certainly difficult to find a good set of axles... We took apart probably 3 rear ends to come up with a good set. If you do not have access to a good pile of axles to go through, the new ones might be worth the money.
02-10-2022, 01:25 PM | #3 |
Re: Rear axles?????
My experience is that I would avoid reproduction rear axle shafts. For one, they are over $600 each and they come with possible failure modes. The gear portion is welded to the shaft, and I have seen several where the weld failed. In years past I encountered several where the gear diameter was incorrect, and they jammed inside the carrier.
Your best bet is to locate originals. Contact Berts in Denver. A serviceable original should have good threads and not have any cracks at the key slot. Tom Endy |
02-10-2022, 07:52 PM | #4 | |
Re: Rear axles?????
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
02-10-2022, 07:57 PM | #5 |
Re: Rear axles?????
02-10-2022, 09:30 PM | #6 |
Re: Rear axles?????
02-11-2022, 01:04 PM | #7 |
Re: Rear axles?????
Just got off the phone with Steve at Bert's, bought a pair from him. Thanks for all the reply's.
02-11-2022, 03:35 PM | #8 |
Re: Rear axles?????
Tom Endy- the welded two piece axles havent been made for several years. The ones made now are one piece, USA made and very nice.
02-11-2022, 06:15 PM | #9 |
Re: Rear axles?????
If the taper on your axles is rough and scored, the hubs will also be rough and scored. A close taper fit is important! This what actually moves the car, not the key! When/if the axle nut is under torqued, the key can shear or wallow out the key. Minor damage can be corrected by lapping with valve grinding compound.
02-11-2022, 07:19 PM | #10 |
Re: Rear axles?????
2 shims on each axle, to keep drum off backing plates. Its time to replace them.
Thank you for the reply. |
02-12-2022, 11:56 AM | #11 |
Re: Rear axles?????
It sounds like you need a stepped key.
