Old 02-04-2022, 07:58 PM   #1
hogluvr
Default Does this sound like a good flathead build?
I am very new to flatheads and considering this rebuilt 8BA.
Does this sound like the guy knows what he's doing?
Bored +.040 with aluminum domed pistons, New rings, main/rod/cam bearings, Chevy stainless steel 1.5” valves, Converted & setup Chevy distributor, Packard plug wires
Litterio L-100 camshaft, Johnson adjustable lifters, New valve guides, Offenhouser #400 aluminum finned heads, Offenhouser aluminum dual carb intake
Holley 94 carbs, PCV system installed, Fenton cast iron headers, New modern water pumps, New Carter fuel pump[FONT=New], Reground flywheel (10” clutch) "
hogluvr is offline   Reply With Quote
