Old 01-08-2022, 10:40 PM   #1
paetsgone
Default Can you id this ford.
I took this photo in a junk yard some time ago and i can't remember what car it was. I think its a 289 but their are no shock towers in the engine bay. Looks like around a 66? What do you think. sorry having problems uploading, last line. its not uploading. sorry no way to delete
thanks
paetsgone is offline   Reply With Quote
Old 01-08-2022, 11:02 PM   #2
mercman from oz
mercman from oz's Avatar
Default Re: Can you id this ford.
A picture would help?
Old 01-09-2022, 10:13 AM   #3
5851a
Without shock towers it will be a full frame car and if it came with 289 would place it between 63 and 67 Full size Ford. Mercury kept the 390 till 72.
5851a is offline   Reply With Quote
Old 01-09-2022, 03:18 PM   #4
dmsfrr
dmsfrr's Avatar
Originally Posted by paetsgone View Post
. . . sorry having problems uploading, last line. its not uploading. ...
The "File Size" of the image has to be just under 2MB to upload it as an attachment. You may have to create a resized copy of the original (digital) photo.
There is at least one other way to include photos but I haven't gone that route yet.
dmsfrr is offline   Reply With Quote
Old 01-09-2022, 08:15 PM   #5
Lanny
Lanny's Avatar
thanks
Paetsgone, Email me the photo, and I will talk to Trevor about posting
an Enlarged copy of your photo.
thx, Lanny...
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 01-09-2022, 09:40 PM   #6
paetsgone
hopefully sending a e-mail to one of you guys in hopes of having the photo posted. very interested in what you will see. purhaps i am missing something.
Old 01-09-2022, 09:43 PM   #7
paetsgone
email send. sorry for the delay was working late.
Old 01-09-2022, 10:28 PM   #8
mercman from oz
Can you ID this Ford ? Question by Scott.
Old 01-09-2022, 10:40 PM   #9
Lanny
Lanny's Avatar
Paetsgone, thanks for sending the picture, and I sent it to Trevor (Mercman)
and he worked his magic and got it posted for you. Thanks Trev.
I wonder if that is a 352 engine in a full size Ford car or maybe pickup.
I can't tell for sure. Some others will chime in here to help identify it.
With that old round single brake master cylinder should help identify the year.
Old 01-09-2022, 10:57 PM   #10
paetsgone
Thanks, hope this will be fun to id just from the engine bay.
scott
Old 01-09-2022, 11:24 PM   #11
58Yeoman
58Yeoman's Avatar
It's not a 63 Galaxie. Mine had the washer bag on the right. And definitely not a 289.
58Yeoman is offline   Reply With Quote
Old 01-10-2022, 12:16 AM   #12
paetsgone
There was a 1966 convertible 4 speed mustang parked next to it. I remember that one. Had couguar taillights mounted and another set laying inside.
Old 01-10-2022, 02:24 AM   #13
KULTULZ
KULTULZ's Avatar
Question Re: Can you id this ford.
It is an FE, most likely LT (352-360-390 2V) as you see how the oil filter is mounted horizontally.
Pre-1967 chassis with SGL RSVR MC (but has an ALT INSTALL - 65/ ).
I would guess GALAXY - CUSTOM.
It was a PASS CAR and not pickup?
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 01-10-2022, 05:59 AM   #14
darrell
its an fe as was said.going by the rocker covers its a 66 or later 390 as that was the only fe using a 2 bbl carb at this time.
darrell is offline   Reply With Quote
Old 01-10-2022, 06:11 AM   #15
darrell
66 was the last year for the single master cylinder.if the motor is original it should be 66.
Old 01-10-2022, 07:09 AM   #16
STEVE O
STEVE O's Avatar
Looks pu by the inner fender and support for the hood hinge.
STEVE O is offline   Reply With Quote
Old 01-10-2022, 07:23 AM   #17
paetsgone
is that a good engine to build. I thought it was a small block 289.
Old 01-10-2022, 08:47 AM   #18
darrell
if its a pickup maybe a 352.i was thinking a galaxie.
Old 01-10-2022, 09:01 AM   #19
KULTULZ
KULTULZ's Avatar
That's what I think but he said car ...
Old 01-10-2022, 10:32 AM   #20
rotorwrench
rotorwrench's Avatar
352 engines were almost as common as 390s. It doesn't have the coolant reservoir attached to the coolant thermostat housing of the manifold and it has an alternator so it's likely 65 or 66. No power brakes or steering so it's a basic model. Likely a 352 unless it's a pickup. An F100 could have either engine. The 360 came out for 1968 & later.
