Old 12-19-2021, 04:58 PM   #1
Crownir1
Default 1932 body webbing
I have a 1932 ford which the body and fenders were all removed before I purchased the car. I realize that webbing needs to be placed on the frame under the body.
Does webbing also go under the firewall? At the factory the firewall was attached to the frame before the body was was mounted?
Does webbing also go on top of the frame and under the front fenders? At the factory the front fenders where mounted after the firewall and the body?
Does it make sense that the body webbing was installed when the body was mounted to the frame and thus was placed only under the body and not under firewall and front fenders?
Thanks for the help.
Crownir1 is offline   Reply With Quote
