#1 |
This is the passenger side head off of the industrial engine I have. Severe damage on the casting, but absolutely no damage to the cylinder or the piston. Just trying to figure out what happened here?
A machinist friend of mine said it could’ve been a flaw in the casting, but I don’t see how it could’ve ran for years if it was a flaw. |
#2 | |
![]() Quote:
#3 |
Hydrolock?
#4 |
#5 |
Compression vs. head and compression won.
#6 |
#7 |
Given the rust and crust in the rest of the engine it will need to come apart anyway. I would very carefully inspect the cylinder bore, rod, and piston for that hole.
#8 |
I’ve seen that in old engines left out to the weather It broke at the weakest point, might have cylinder wall cracks as well.
#9 |
Rust or weak casiting in combustion chamber or a combination and the compression finally caused it to give way.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
