Old 12-04-2021, 09:28 PM   #1
Fatheads4ever
Fatheads4ever's Avatar
Default V8 piston rings
Hi Guys.. I was checking the ring gap of my new rings when I noticed that the box was missing a spring tensioner on the third oil control ring. 2x times thin steel flat rings separated by a wiggly spring. The wiggly part is missing.
There are 4 ring grooves with the 4th ring being cast iron.
Can I just install 3 rings and leave the 3rd one out?
Can I install the 4th ring in the 3rd ring position?
I've got some old pistons with rings so could I use a second hand piece in the new pistons?
Ideas anyone?
Regards Kevin
Fatheads4ever is offline   Reply With Quote
Old 12-05-2021, 07:56 AM   #2
Desoto291Hemi
Default Re: V8 piston rings
The wigley piece is just an expander,,,,the thin flat rings are what cleans the oil off the cylinder wall .
They wear,,,the expander doesn’t .
You should be good if you need to reuse one .
Tommy
Desoto291Hemi is offline   Reply With Quote
Old 12-05-2021, 02:10 PM   #3
Fatheads4ever
Hi Desoto.. the 2nd hand expander is off a +40thou piston. The new pistons are +80thou that is a difference of 40thou or 1mm in metric speak. The height seems right. I'm don't want the engine to chew much oil.
Old 12-07-2021, 04:20 PM   #4
Desoto291Hemi
The expander is the same,,,,,the thin rings should be all that is larger o.d.
If you have new oil rails,,,,it should be good .
Tommy
