12-01-2021, 03:21 PM | #1 |
flow testing Model A Zenith carb jets
Can anyone explain the reason for flow testing Model A Zenith carb jets with a 36 inch water column instead of the 37 1/4inch column as used by Ford? Thank you.
12-01-2021, 08:12 PM | #2 |
Re: flow testing Model A Zenith carb jets
here u go.
www.whidbeymodelaclub.com |
12-02-2021, 08:22 AM | #3 |
Here are some charts to make life easy.
http://www.fordgarage.com/pages/jetflowrates.htm I tested many jets using the Ford column length. I did a lot of error checking and repeating and found the results were very consistant. Most seemed to flow too much by a little to a lot and some were on the money. A few did not have a nice stream indicating there was a problem with the hole and flow. |
12-02-2021, 06:19 PM | #4 |
I have rebuilt and sold over 200 model A zenith carbs and have always gone by the drill size for all the jets...Merry Christmas
12-04-2021, 02:39 PM | #5 |
One thing I have seen someplace is; when soldering the hole up to resize, how thick the solder is before you redrill the hole can change the rate of the flow. So if it calls for X size hole, might have to go to larger or smaller drill to get the correct flow.
12-04-2021, 05:02 PM | #6 |
Technical Note on Flow-Testing - Gary WA |
