Old 11-28-2021, 12:37 PM   #1
Bill Cal.
Default A head on a B block
Does anyone know if there is a problem running an A head on a B block?
Thank you for your thoughts.
Bill Cal. is offline   Reply With Quote
Old 11-28-2021, 02:04 PM   #2
Gary WA
Gary WA's Avatar
Default Re: A head on a B block
No Problem
www.whidbeymodelaclub.com
Old 11-28-2021, 09:22 PM   #3
Charlie Stephens
If I remember correctly you need to plug two water holes in the block. Drill them, tap them and put an allen screw in with sealer. They are too close to the edge of the gasket.
Due to the shape of the combustion chambers you can run a A6050B head (the "Police" head) without plugging the holes.
Charlie Stephens
Last edited by Charlie Stephens; 11-28-2021 at 10:22 PM. Reason: added info on police head
Old 11-28-2021, 10:40 PM   #4
CarlG
CarlG's Avatar
In our club we have both:
• A head on a B block
• B head on an A block
No problems either way.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-29-2021, 08:41 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
This should help you understand the differences in cylinder blocks. It is not necessary to plug the water holes in the "B" block regardless of the head gasket you use. An "A" gasket seals the 2 water passages, and the "A" cylinder head seals the water passages if you use a "B" gasket. I have done this both ways without any issues.
File Type: jpg A & B Cylinderr Head Gasket Applications.jpg (77.6 KB, 40 views)
Bob Bidonde
Old 11-29-2021, 01:21 PM   #6
Jim Brierley
The problem is that after 90 years the area around those 4 small holes in B blocks can be enlarged from corrosion, so need plugging. Plugs must be flush with the block to support the gasket, not merely plugged to seal water. If using the A head, an A gasket must be used, the gasket must fit the head.
Jim Brierley is offline   Reply With Quote
Old 11-29-2021, 06:37 PM   #7
MAG
MAG's Avatar
Take a look at the steam holes on each side of the stud hole (circled)in Bob's B picture. Two of them. These are steam holes not water holes. They must be plugged as mentioned.
Notice they are not there on the A block.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
