Old 11-20-2021, 05:25 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Whatchamacallit
On the ends of your choke and throttle rods there is a spring loaded whatchamacallit that you slide back in order to attach or detach the throttle/choke rod to the carburetor linkage. What is the correct nomenclature for that piece? Is that piece available by itself. Most are "crimped" on but I have an old rod, maybe off of an 8N as it was painted red eons ago, that little gizmo that screws onto a threaded rod with an added lock nut. Never seen that type before. Anywho, I would like to get a couple of the removable type if they are available. I think they would look better than putting an adjustable sleeve in the middle of the throttle rod. Sort of makes the rod look like a snake that swallowed a rat.
(Why are you so hung up on this little rod, Lawson? I dunno, maybe that's about all I'm capable of doing nowadays, the small stuff, but I gotta do something or I'll go bonkers.)
Thanks for any input guys & Gals.
Old 11-20-2021, 06:48 PM   #2
WABOOM
WABOOM's Avatar
Default Re: Whatchamacallit
Spring and ball detent ?
WABOOM is offline   Reply With Quote
Old 11-20-2021, 07:29 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Speedway has these ends that you can use to make any length of rod.
https://www.speedwaymotors.com/Carb-...-RH,37495.html
Old 11-20-2021, 07:38 PM   #4
Lawson Cox
Lawson Cox's Avatar
Sorta close, but what's with the cotter pin? Strange.
Old 11-20-2021, 07:50 PM   #5
tubman
tubman's Avatar
There is a deep slot in the set screw that screws into the end of the main body. Once you get the tension right, you insert the cotter pin to engage that slot to keep the set screw from loosening up. They must figure 1/2 turn adjustment is close enough.
Old 11-20-2021, 07:56 PM   #6
ford38v8
ford38v8's Avatar
Lawson, you claim to be a Fordnut and yet you consider cotter pins to be strange? Now THAT is strange.
Alan
ford38v8 is online now   Reply With Quote
Old 11-20-2021, 08:07 PM   #7
petehoovie
petehoovie's Avatar
WEBER CARBURETOR Adjustable linkage rods- 3 1/4 TO 5 INCH LINKAGE ADJUSTABLE ROD
https://www.amazon.com/CARBURETOR-Ad...456307&sr=8-25
https://www.amazon.com/Release-Autom...456793&sr=8-15
Quick Release Ball End aka Throttle Ball Joint Release
https://www.amazon.com/Allstar-Perfo...456676&sr=8-28
Part # 5600001
Double End Carburetor Linkage, 3 Inches Long, Non-Adjustable
https://www.speedwaymotors.com/Doubl...ble,37530.html
Old 11-20-2021, 08:52 PM   #8
47Monarch
47Monarch's Avatar
Try joe's antique auto auto in Massachusetts
47Monarch is offline   Reply With Quote
Old 11-20-2021, 08:59 PM   #9
Lawson Cox
Lawson Cox's Avatar
Alan, a cotter pin is very familiar to me, it's the location that's weird. LOL
Old 11-20-2021, 09:41 PM   #10
Lawson Cox
Lawson Cox's Avatar
Part # 5600001
The left end on the bottom picture is what I have in mind. I'll check with Joe's in Mass and see what he has. Maybe he even makes them up to to order. Fingers crossed.
Thanks to all for your comments and suggestions. They are greatly appreciated.
Old 11-21-2021, 05:39 AM   #11
fortyonerag
fortyonerag's Avatar
These ball and socket fittings remind me of L'Hotellier fittings used in aircraft control rods.
fortyonerag is offline   Reply With Quote
Old 11-21-2021, 07:19 AM   #12
corvette8n
corvette8n's Avatar
I bought some of those for my Ford 8N, either Dennis Carpenter or www.just8n.com picture is from Carpenters catalog.
File Type: jpg 9847E69B-B2CC-4D4E-BA8D-53F3F938EC64.jpg (29.9 KB, 57 views)
Old 11-21-2021, 07:47 AM   #13
51 MERC-CT
51 MERC-CT's Avatar
A couple of links that may help---
https://www.yesterdaystractors.com/F...nd_8N9740.html
https://www.dennis-carpenter.com/tra...ontrol-rod-end
Old 11-21-2021, 10:02 AM   #14
Lawson Cox
Lawson Cox's Avatar
Getting mighty close. I believe the rod on the 8N, that these attach to is a little smaller than what is on the Ford vehicles however. I'll probably settle for these unless Joe's Mass has the correct ones. Thanks a heap. 51 MERC-CT
Old 11-21-2021, 10:53 AM   #15
Clem Clement
Clem Clement's Avatar
Why does the carb on my 40Merc need an anticattle cap on the throttle/carb rods?
Clem Clement is offline   Reply With Quote
Old 11-21-2021, 11:38 AM   #16
Lawson Cox
Lawson Cox's Avatar
I believe they all had what you call the "anti cattle cap" back in the day. It is the multiple carb linkage that uses the weird "side saddle" style ends. LOL
