#1 |
Heres a question for some of you gurus to ponder: all of the 6v fords, from abou 32 and up use an ignition resistor in the primary side of the ignition so the points won't burn. Why doesn't Model A and most other 6v cars of that era use one?
#2 |
They have an internal resistor - inside the coil?....
#3 |
Note: Because of the meds I am currently on, my responses may or may not be totally coherent!!
