Old 11-07-2021, 03:10 PM   #1
adileo
adileo's Avatar
Default Oil consumption
Hi guys
Recently went a long (200 miles round trip) highway run, with my stock 52 F1. I did an oil change prior to the trip. So I know, level was good at start. I pretty much kept it at 55 mph, the entire ride Truck ran great, however this morning, I see I’m down a qt. I would guess this is normal, as the engine hasn’t been rebuilt to my knowledge.
Truck does not smoke and with normal local driving it doesn’t burn oil.
What’s your thoughts?
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 11-07-2021, 03:55 PM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Oil consumption
Let's see. A 70 yo unrebuilt flathead. 55mph for 200miles. Down a quart. Sounds good to me. 8^)
Jack E/NJ is offline   Reply With Quote
Old 11-07-2021, 04:55 PM   #3
FortyNiner
FortyNiner's Avatar
Did you check the pre-trip oil level after the filter was filled?
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 11-07-2021, 05:30 PM   #4
adileo
adileo's Avatar
Thanks guys and yes canister was full. That’s was a good thought and certainly would have made a difference.
Thanks
Andy
1952 F1
Old 11-07-2021, 06:21 PM   #5
tubman
tubman's Avatar
Install a PCV valve; it'll help a LOT.
Old 11-07-2021, 08:27 PM   #6
Crankster
Crankster's Avatar
Have you ever performed a compression test? One thing mentioned in the old Motors Repair Tune Up manual in the Tune Up chapter, worn piston rings and cylinder bores will result in lower compression. But it goes on to say that oftentimes the issue isn't necessarily excessive wear, the problem is stuck piston rings due to carbon and gum varnish, and will cause low compression readings. "A solvent will help with this".
After 70 years it would not be surprising if there is some of that going on. This would also tend to cause problems with oil control. I'd be inclined to try Marvel's in both the crankcase oil and in the fuel tank per their directions. It was designed for this purpose and it does work really well at removing carbon.
Crankster is offline   Reply With Quote
Old 11-07-2021, 08:44 PM   #7
Holeshot
Add a quart of oil and keep on truckin!
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament."
Holeshot is offline   Reply With Quote
Old 11-07-2021, 09:53 PM   #8
38 coupe
38 coupe's Avatar
Keep a couple spare quarts of oil in the tool tray on top of the gas tank and drive it.
Old 11-08-2021, 02:25 AM   #9
40 Deluxe
You could pull the spark plugs for a quick look. If they all look about the same you're good to go. If only one or two are oil fouled, you could have a broken ring or a wrist pin keeper has broken and the wrist pin is gouging the cylinder wall.
