Old 11-06-2021, 02:58 PM   #1
48fordnut
48fordnut's Avatar
Default 12 volt 2 3 psi fuel pump
What is a good 12 volt elect fuel pump, 2 to 3 psi? And regulator if necessary.
Thanks,
jim
48fordnut is offline   Reply With Quote
Old 11-06-2021, 04:23 PM   #2
Synchro909
Synchro909's Avatar
Default Re: 12 volt 2 3 psi fuel pump
They are getting to be a bit old now but if you can find a carburettor model Subaru in a wrecker's yard, the fuel pump will be just what you want. I use one on each of my As. They are the right pressure, cheap and very reliable. No pressure regulator is needed so that's one less thing to go wrong.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 11-06-2021, 04:50 PM   #3
4port
4port's Avatar
Aircraft Spruce and Specialty will have the best price on quality Facet pumps. 6v and 12v
4port is offline   Reply With Quote
Old 11-06-2021, 10:13 PM   #4
bruceincam
bruceincam's Avatar
Edelbrock makes a nice little 3.5 psi pump that doesn't need a regulator. Part #17303. About $80.
bruceincam is offline   Reply With Quote
Old 11-06-2021, 11:21 PM   #5
48fordnut
48fordnut's Avatar
Thanks all.
jim
Old 11-07-2021, 05:19 PM   #6
Certimafied
Certimafied's Avatar
I just picked up and used a mr.gasket brand 3-5 psi electric 12v pump from my local autozone. It worked great on the amphicar I installed it on, though the pump is only being used to prime the mechanical pump after long storage periods. I can’t speak on its ability to feed a running driving engine.
Edit:
Ive got to correct myself. I went back and looked up the pump I got it was a 2.5-3 psi pump.
Mr.gasket 42S. Autozone part #: 42S
Certimafied is offline   Reply With Quote
