11-05-2021, 10:10 AM | #1 |
blasting
The cost of blasting is like everything else going thru the roof. I got a price of $60. per Model A wheel. Is that about normal?
11-05-2021, 10:34 AM | #2 |
Re: blasting
sounds a little high to me, but what isnt?
I would think 40. a wheel would be about right. |
11-05-2021, 11:27 AM | #3 |
Re: blasting
I bought a large blast cabinet from Skat Blast. That way I can blast what I want, when I want. It’s been very handy and I use it for lots of things.
11-05-2021, 12:38 PM | #4 |
Re: blasting
11-05-2021, 12:45 PM | #5 |
Re: blasting
takes allot of time to blast a wire wheel
11-05-2021, 01:01 PM | #6 |
Re: blasting
out of curiosity- how long? |
11-05-2021, 01:36 PM | #7 |
Re: blasting
I think that depends on equipment big compressor and sandblast blast pot not long .
Dennis in Kelsey ca |
11-05-2021, 02:09 PM | #8 |
Re: blasting
The sandblasters here charge more if the wheels have been powder coated as it is a lot harder to remove than paint.
11-05-2021, 02:34 PM | #9 |
Re: blasting
I have an Ingersoll Rand 185 Diesel powered compressor. I can blast one Model A wheel in 20 minutes. I use the Dustless water blaster and it really kicks ass. I was wondering about the price because I suddenly became very popular.
11-05-2021, 02:52 PM | #10 |
Re: blasting
well I think 60 a wheel is high, but what do I know?
11-05-2021, 03:08 PM | #11 |
Re: blasting
Depends on where you live.
They wanted $60 a wheel here in NJ a bunch of years ago. People were doing it for $30 a wheel in the south where peoples time is undervalued which can be profitable for some. But that is another story. Between cost of the tools, time it takes to do it right, and just how nasty blasting is I would say $60 is cheap. Depending on the paint, I found I saved a lot of time by letting each wheel go in a electrolytic rust removal tank. This removed some of the paint and a bunch of the rust. This significantly reduced the time blasting. |
11-05-2021, 03:13 PM | #12 |
Re: blasting
If you plan to use powder coat you should talk to the company doing the powder coating. The company that did my wheels said they would blast any wheels that had been blasted by another company. Apparently they didn't want to gamble on how long it had been since they were blasted and if they had been contaminated by handling.
Charlie Stephens |
11-05-2021, 03:40 PM | #13 |
Re: blasting
Powder coating requires the metal to be absolutely clean. After I blast mine, I wrap them in a plastic trash bag and take them imediately to the powder man. I just finished blasting 19 inch wheels. Took 20 minutes each and 2 fifty pound bags each wheel of crushed glass.
11-05-2021, 03:53 PM | #14 |
Re: blasting
Is it possible to burn off the paint or powder coating before blasting? Or would this destroy any metallurgical properties the wheels may have, or warp them?
11-05-2021, 04:26 PM | #15 |
Re: blasting
Here in so. cal I found a company called LINCO INDUSTRIES,INC located in Anaheim. They do chemical stripping, blasting and plating. I had a '30 hood that had been painted and had minor fire bubbling, surface rust. I was happy to pay $75. I was very pleased with the work, turnaround and friendly attitude for such a small job. They specialize in wheel repair. Ask for Dean 714 635-2800
11-05-2021, 06:14 PM | #16 |
Re: blasting
Try doing a wheel in a hobbyist blast cabinet….
You’ll pay $60 in a heartbeat. Oldred has a 185 which would Run a decent outside pot. Buying 60# fine sand a tractor supply is $11. A wheel would take a minimum of a bag per wheel maybe two Agree with Kevin you’ll find $50 palatable in the end |
11-05-2021, 07:18 PM | #17 |
Re: blasting
11-05-2021, 07:24 PM | #18 | |
Re: blasting
I highly recommend Skat Blast for anyone looking for a blast cabinet. I use it all the time.
Jim |
11-05-2021, 07:47 PM | #19 |
Re: blasting
Do NOT use sand for 'sand'blasting, it will cause silicosis.
Understood but I use a fresh air system and enclosed Good comment to those that don’t have such |
11-05-2021, 09:22 PM | #20 |
Re: blasting
Another off topic point to make is many use the term sandblasting as a blanket term to cover any type of abrasive blasting. Most people are using coal slag these days.
"The more things change, the more they stay the same." |
