Old 11-04-2021, 04:56 PM   #1
1936 ford pickup
Default 2-Door Flat Glass Power Window Motor Conversion
Hello to all,
Just wondering if anyone has had any experience (good or bad) with installing the 2-Door Flat Glass Power Window Motor Conversion.
I was "thinking" about possibly Purchasing and installing into my '36 Ford pickup.
Bruce in California
1936 ford pickup is offline   Reply With Quote
Old 11-04-2021, 06:56 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 2-Door Flat Glass Power Window Motor Conversion
Originally Posted by 1936 ford pickup View Post
Hello to all,
Bruce in California
There are two different types of power window kits.
The one I have does not turn the window crank. It has not given any problems in 20 plus years of operation.
The window crank turner type looks interesting and should work well.
If you have a 12 volt system and there is a square window crank adapter in the kit, it looks interesting. (they are cheap enough)
Old 11-05-2021, 09:05 AM   #3
1936 ford pickup
Hello 51 MERC-CT
THANK YOU for your reply. I was thinking of Purchasing the Kit that does not turn the window crank (like yours).
Good to hear it has not given any problems in 20 plus years of operation.
Bruce
Old 11-05-2021, 09:58 AM   #4
37 truck
Switching to power windows in a 36 pickup would not be a problem, but the original cranked type moved up then forward to close. You would lose the forward motion, sometimes referred to as smokers vent. Some power window producers take the original linkage so you don't lose the slide back function.
37 truck is offline   Reply With Quote
Old 11-05-2021, 11:53 AM   #5
1936 ford pickup
Hello 37 truck,
GOOD information....THANK YOU....
Old 11-06-2021, 12:04 AM   #6
rich b
rich b's Avatar
Not sure what brand you are looking at; but not all the products are equal. I've worked with several kits from Specialty Power Windows; good stuff.
Also dealt with an Autoloc set-up not so good; probably the same stuff Johnny Law and the the other Hoffmann companies peddle.
Thin doors are fun.
rich b is offline   Reply With Quote
Old 11-06-2021, 06:50 AM   #7
flatmotor40
flatmotor40's Avatar
I've always use Specialty Power windows.Doing a 35 Chevy now ansd ahd a problem with rrear side glass and the changed the power regulator so I can get the window down farther.But they are 16 miles from me and I went down to the shop and he came back to my house and we worked it out.They are great to work with
flatmotor40 is offline   Reply With Quote
Old 11-07-2021, 08:56 PM   #8
don35
Also, beware of off brand kits. If you need parts, you could be in trouble.
don35 is offline   Reply With Quote
