Old 10-25-2021, 12:06 AM   #1
Fatheads4ever
Fatheads4ever's Avatar
Default Cam bearing
Hi gang.. I've decided replace the cam bearings since the engine is apart. I noticed that the old front bearing closest to the timing cover has two semi circular notches 180° apart cut into the fwd edge.
Any ideas why?
Should I do the same to my new bearing?
Regards Kevin
Fatheads4ever is offline   Reply With Quote
Old 10-25-2021, 05:52 AM   #2
ponymare
Default Re: Cam bearing
Mabey to let more oil get to the cam flange?
ponymare is offline   Reply With Quote
Old 10-25-2021, 07:49 AM   #3
big job
big job's Avatar
maybe another who knows what was done. the only two hole bearing I can think of is the rear, the extra hole is for the fuel pump push rod. Whether the front and rear measurements are the same I don't know been couple yrs since I did one. Question you popped out all cam bearings so you should have two now with these holes front and rear?
possible a rear was used in the front weird .....sam
big job is offline   Reply With Quote
Old 10-25-2021, 08:50 AM   #4
34PKUP
34PKUP's Avatar
Suggest you read post #1 again, it's not holes that are in question but "notches"
34PKUP is offline   Reply With Quote
Old 10-25-2021, 09:10 AM   #5
flatjack9
flatjack9's Avatar
Notches are not normal.
Old 10-25-2021, 09:17 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
Any ideas why?
Regards Kevin
If your new bearings have the notches, install the same as the ones removed (I would not install notches in the bearing)
As previously stated the notches were probably to provide oil to any thrust faces.
Have not seen any new bearings with the notches.
Old 10-25-2021, 10:00 AM   #7
Bored&Stroked
Bored&Stroked's Avatar
All three bearings have TWO holes, but the rear one must have one with the BIGGER hole up top - for the fuel pump pushrod.
If you didn't have two holes, you'd not have oil going to the main bearings.
Old 10-25-2021, 01:35 PM   #8
Ronnieroadster
Ronnieroadster's Avatar
Any ideas why?
Regards Kevin
Kevin the two notch's were no doubt added to the front edge of the cam bearing by someone so additional oil would eventually get onto the cam thrust face of the block. There's no need to add them to the front bearing your using as a replacement. The new cam bearing has a certain amount of clearance so that oil coming out of the end will lubricate the block-cam thrust surface perfectly.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 10-25-2021, 07:45 PM   #9
Bored&Stroked
I can see no reason that notches would have any value in the least. The cam bearing has about .002 clearance to the cam journal, do there is plenty of lubrication getting to the front thrust surface. Also, if it is earlier than 1949, then the front pressure relief system also throws oil onto the back of the timing gear. Plenty of oil in this area. I've never seen a cam that "burnt" on the thrust surface.
Old 10-26-2021, 12:26 AM   #10
Fatheads4ever
Thanks guys.. I've decided to not file the notches.. I'm sure the thrust face will get oil as suggested. Now to continue with the assembly.
I may be slow but boy am I rough.
Old 10-26-2021, 04:22 AM   #11
big job
big job's Avatar
True My brain wakes up around noontime hate gettin old.....
Old 10-26-2021, 06:17 AM   #12
Bored&Stroked
You're doing just fine my friend! We all have our good days and then the ones that we're not happy with.
