Old 10-20-2021, 01:43 PM   #1
farmertom
farmertom's Avatar
Default upper radiator hoses
hi barners, i ordered 2 radiator hoses from joe's antique today. wondering how much coolant to drain from radiator to replace both upper hoses? iv'e had the'37 fordor for two years and havn't had to do any coolant work yet. i hope i can get the pet cock to shut off after draining a little coolant. thanks in advance, tom. oh also ordered 2 160 deg. thermostats. how are those supposed to be installed.
Last edited by farmertom; 10-20-2021 at 01:47 PM. Reason: forgot to add additional info
farmertom is offline   Reply With Quote
Old 10-20-2021, 02:57 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: upper radiator hoses
I believe you should use 180° thermostats. 160° is a little cool IMHO.
Old 10-20-2021, 06:04 PM   #3
JSeery
JSeery's Avatar
Agree, 160 is a bit cool, I would use 180 min, 185-190 better.
Old 10-20-2021, 07:53 PM   #4
J Franklin
J Franklin's Avatar
Might as well do a full drain and flush while it is down. How much are you saving doing it half-ass.
180 on the stat. but the ones you bought will get the temperature up as quickly but not as high. I have 160 degree ones in my A and I don't worry one bit.
