Old 10-18-2021, 11:05 AM   #1
skeazle
Default Oil Pan Gaskets
Anyone know which is the best oil pan gasket material to use, cork or paper? I haven't dropped my pan yet and I am not one hundred percent sure I need new gaskets but I have a lot of oil leaking between the oil return pipe and the top of the oil pan. I think it's coming from either the oil pipe or the oil pan but either way I want to replace all the gaskets involved. Jim
skeazle is offline   Reply With Quote
Old 10-18-2021, 11:10 AM   #2
bavArian
bavArian's Avatar
Default Re: Oil Pan Gaskets
Use new gaskets, I don't think the old ones will seal 100% again.
I used the cork gaskets and have absolutely no oil leak. (didn't try the paper ones)
Also it makes it a lot easier if you glue the gaskets to the pan with 2 or 3 small drops of superglue before putting the pan back on.
bavArian is offline   Reply With Quote
Old 10-18-2021, 11:16 AM   #3
skeazle
Thank you bav Arian, I will try the cork ones.
Old 10-18-2021, 03:17 PM   #4
Werner
Werner's Avatar
I have a note on this subject:
During my engine overhaul, I used the thick cork seals for the oil pan. After about 2000 miles, the engine got a lot of oil leakage from the rear bearing seal. About 200 cc / 100 mls.
I'm now thinkin' that a thin paper seal with sealing paste would have been better because then the rear cork seal is pressed more strongly against the rear crankshaft bearing.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 10-18-2021, 05:49 PM   #5
burner31
burner31's Avatar
Cork, take your time and do it right and it won't leak.
Extra care to detail on the rear, there is a right way and a wrong way to do it...do it the right way.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 10-18-2021, 05:54 PM   #6
1crosscut
1crosscut's Avatar
If it is the oil return pipe leaking and not the oil pan then for sure just change the gaskets for the oil return pipe and don't mess with the oil pan. Wipe everything clean and check with a bright flashlight until you know where the leak is coming from.
I like to use cork.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-18-2021, 06:13 PM   #7
skeazle
Thanks. I am going to do the easiest thing first by replacing the oil pipe gaskets. Do I have to drain the oil to change them? I figured not cause all the oil would be settled down in the pan.
Old 10-18-2021, 06:13 PM   #8
1crosscut
1crosscut's Avatar
No need to drain the oil.
Old 10-18-2021, 06:19 PM   #9
old ugly
old ugly's Avatar
cork
if your lucky and its just oil return pipe gasket leak. don't take the pan off just for the fun of it.
old ugly is offline   Reply With Quote
Old 10-18-2021, 06:25 PM   #10
hardtimes
hardtimes's Avatar
If you can locate pan gasket that is a mix of cork and rubberized material … this is best.
Do not waste $, effort and time with ….OLD BRITTLE cork and or paper gaskets. If using these materials, at least use FRESH !
If you want the best…. as said….cork mixed with rubber.
hardtimes is offline   Reply With Quote
Old 10-18-2021, 06:50 PM   #11
1crosscut
1crosscut's Avatar
I put a small bit of RTV under the flat copper washers and under the heads of the bolts for the oil return pipe. Just a little extra insurance to prevent a leak.
Old 10-18-2021, 08:15 PM   #12
nkaminar
nkaminar's Avatar
I have had good luck smearing a THIN coat of silicone gasket sealer on both sides of the pan gasket. I snug up the bolts, allow the sealer to cure, and then tighten the bolts. That way the silicone is in compression and not squeezed out of the joints. The bolts should be initially tightened to get 100% contact. I will clean any old gasket out but not have surgically clean parts because a very tiny film of oil will allow the gasket to release next time I have to remove the pan. Same technique on most other gaskets, but not the head.
Old 10-18-2021, 08:19 PM   #13
chrs1961815
chrs1961815's Avatar
I like the paper gasket but the cork ones are OK too. Whatever you do, don't use the cork-rubber one!!! They swell up and leak after a little while. Found it out the hard way. The oil pan doesn't usually leak from the sides, it leaks from the rear main or front timing cover.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-19-2021, 04:12 AM   #14
alexiskai
alexiskai's Avatar
I love this board.
Old 10-19-2021, 05:23 AM   #15
Benson
1. Paper gaskets are good.
2. Cork / Rubber work better IF torqued no more than about 7 foot pounds.
If too tight they are smashed and leak. Same thing with VW and GM valve cover gaskets.
3.IN THE PAST, the Black Neoprene gaskets for the glass sediment bowl are a major problem and are worthless when they turn to mush and leak when used with Ethanol gasoline.
Real bummer when you find the problem on the side of the road and do not have a spare gasket.
Benson is offline   Reply With Quote
Old 10-19-2021, 05:29 AM   #16
SAJ
SAJ's Avatar
The 1/8th inch neolangite rubberized cork uses oil proof nitrile rubber. I have not seen it swell.
We managed to extrude a rubber gasket out of a fork lift sump by tightening it fully whilst silicone sealant was still wet and very slippery, many years ago. Since then we do as someone else said above and partially tighten, let the silicone cure overnight and then fully tighten.
SAJ in NZ
SAJ is offline   Reply With Quote
Old 11-20-2021, 03:39 PM   #17
dmaxweb
dmaxweb's Avatar
Has anyone used a BESTgasket brand oil pan gasket?
Are the sold by any of the vendors?.
dmaxweb is offline   Reply With Quote
