Old 10-15-2021, 10:59 AM   #1
corvette8n
corvette8n's Avatar
Default Head gasket reuse question
I have a spare 40’s flathead I bought a few years ago, I want to mount it on an engine stand and run it, I pulled the one head off last year to check the cylinders, they look good, can I just reuse the gasket to test the motor?, do I need to coat it with anything? It has a graphite gasket on it now.
Old 10-15-2021, 11:26 AM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Head gasket reuse question
If it's surfaces are still decent, I'd use wheel bearing grease if it was mine.
Jack E/NJ is offline   Reply With Quote
Old 10-15-2021, 12:00 PM   #3
WABOOM
WABOOM's Avatar
With a Graphtite that wasn't leaking I definitely slap it back on.
WABOOM is offline   Reply With Quote
Old 10-15-2021, 12:01 PM   #4
Mart
Mart's Avatar
Give it a go. What's the worst that could happen?
I reuse copper gaskets. Not tried a graphite one, but would try it for a test run. It depends on how cleanly it came off, but if any remnants are on the head or block, leave them in place. Just my hunch.
Mart.
Old 10-15-2021, 01:39 PM   #5
19Fordy
19Fordy's Avatar
Here's some helpful info. about reusing copper gaskets.
https://www.fordbarn.com/forum/showt...r+head+gaskets
Old 10-16-2021, 02:16 PM   #6
Ronnieroadster
Ronnieroadster's Avatar
If the gasket was copper you can reuse it many times over. If its one of them there composition type gaskets its going to be a gamble for sure if it will seal correctly.
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
