Old 10-14-2021, 11:48 AM   #1
mrtexas
mrtexas's Avatar
Default 49 master cylinder
Anyone recognize what MC this is? It is on my 49 wagon.
Just discovered the brake light had never been hooked up by the prior owner! Not a good assumption to assume it will work. Have to add a brake light switch. It had a mechanical switch but never hooked up. Searched the EZ wiring harness and found the brake switch wire this morning.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 10-18-2021, 08:11 AM   #2
42merc
42merc's Avatar
Default Re: 49 master cylinder
It looks like a universal after market copy of a late 60's Corvette cylinder.
They are available in several bore sizes, so if replacing, check or match the bore.
42merc is offline   Reply With Quote
Old 10-18-2021, 01:37 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Boy, I would LOVE to see the "late 60's Corvette" that had a M/C looking anything like this one. MAYBE late '90s! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-18-2021, 03:50 PM   #4
42merc
42merc's Avatar
For the all knowing, go to Google or Eckler's site & look at '68 - '72 Corvette master cylinder.
I can't get it transferred.
petehoovie , where are you?
Old 10-18-2021, 05:09 PM   #5
JSeery
JSeery's Avatar
Corvette (in the late 60s, early 70s) should look something like this.
Old 10-18-2021, 07:34 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Seem to recall that a number of years ago a conversion kit supplier offered a master cylinder with outlets on both sides to allow easier fitting of outlet tubes.
The unused ones were plugged.
Old 10-18-2021, 08:17 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Straight from Eckler's site....just like JSeery's example. DD
T5 W/TORQUE TUBE
