10-11-2021, 07:16 AM | #1 |
34 front window size
I have a 34 5 window that came with no glass, can someone tell me the right size for the front doors.
10-11-2021, 09:39 AM | #2 |
Re: 34 front window size
It would be very difficult to convey the glass "size" without an accurate detailed drawing since the glass has only two straight edges and the rest is compound curves. I suggest Bob's Classic Glass or any number of vendors who can supply this.
10-11-2021, 09:43 AM | #3 |
Check with Drake. they used to sell glass patterns. Or check with an older glass shop in your area as they may have patterns on file.
10-11-2021, 10:31 PM | #4 |
Here's a picture of a 5 window door glass I saved a long time ago, it might give you an idea of what's needed.
10-11-2021, 10:47 PM | #5 |
Dimensions of front Window Glass for 1934 Ford Five Window Coupe, as supplied by johnboy34 |
10-12-2021, 12:22 AM | #6 |
10-16-2021, 11:37 AM | #7 |
It's pretty easy to use the car as a pattern for the front curved part of the window along with the measurements in the picture I showed you.
