Old 10-02-2021, 09:08 AM   #1
Dan39Deluxe
Dan39Deluxe's Avatar
Default Hot Water Heater bad core?
Hey guys,
The Hot Water Heater that came in my 39 leaks water out of the core, I bought another one on ebay and that also leaks water out of the core.
Is this very common with these having cracked cores? Would I expect a third one to also be cracked if I buy another one?
thanks
Dan39Deluxe is offline   Reply With Quote
Old 10-02-2021, 09:58 AM   #2
TJ
TJ's Avatar
Default Re: Hot Water Heater bad core?
The problem is you are buying used cores. Look around for a new one.
Old 10-02-2021, 10:01 AM   #3
flatford8
flatford8's Avatar
They’re 80 yrs old. You need to find an old time radiator repair shop to either repair them or find a way to adapt a newer core into one of those heaters………Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 10-02-2021, 01:33 PM   #4
hotrodart
hotrodart's Avatar
Any decent radiator shop should be able to put a new core between your old heater core ends. Had mine done about 30 years ago......was a bit pricey but they did a good job.
hotrodart is offline   Reply With Quote
Old 10-02-2021, 02:10 PM   #5
Dan39Deluxe
These look really hard/expensive to repair, they are soldered together around the whole core.
My dad is thinking about building his own core for it with copper brake line coiled back and forth.
Good idea?
Old 10-02-2021, 02:16 PM   #6
flatford8
flatford8's Avatar
I’d get a price from a shop first…… but it’s you car, your choice…… Mark
Old 10-02-2021, 03:20 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Good idea?
I think you'll find that the copper tubing is mostly a vessel to get the hot water in the vicinity of the heater's fan. It's the very thin fin material which is normally attached to the coils that carries the heat away from the coils and dissipates that heat into the air stream of the fan. You'll also usually find that the tubing in heaters/radiators is of a very thin wall so as to dissipate heat at a quicker rate to the finned media. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-02-2021, 03:25 PM   #8
joe 1950
joe 1950's Avatar
A good radiator shop can handle a simple core exchange but you need to shop around the shop here in town does plenty of them but they’ve been here 50 plus years bring the old one with you
joe 1950 is offline   Reply With Quote
Old 10-02-2021, 03:56 PM   #9
Bob C
Is it a factory or after market heater? Maybe post a picture of the core.
Old 10-02-2021, 10:40 PM   #10
fordor41
fordor41's Avatar
check out Hemmings. there's usually a bunch of shops that can recore your core.
fordor41 is offline   Reply With Quote
Old 10-02-2021, 11:46 PM   #11
J Franklin
J Franklin's Avatar
Cores somtimes can be repaired by a radiator shop if it isn't rotted out..
Old 10-03-2021, 06:42 AM   #12
oldskool
oldskool's Avatar
i had mine recored by cap a radiator in farmingdale ny there an old fashion shop,not cheap expect to pay $200 but well worth it, you can send your core to them
oldskool is offline   Reply With Quote
