Old 09-14-2021, 09:31 AM   #1
old Tom
Default transmission
Back in the 50.s I had a model A 1930 coupe. with the trans in 3rd gear I could pull up the shift lever and move it all the way to the right. I now have a 1929 spots coupe and I can not do this. Were all Model A,s able to do this?
old Tom is offline   Reply With Quote
Old 09-14-2021, 09:46 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: transmission
Yes.
The weaker the spring that holds the shift lever into the transmission top, the easier it is to do this.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-14-2021, 10:46 AM   #3
J Franklin
J Franklin's Avatar
How much older are you? we tend to forget some losses as they come gradually. I was about to change headlight bulbs as I thought the light were too dim until I had cataract surgery.
Old 09-14-2021, 03:28 PM   #4
old Tom
You might be right I am 80 now and was 14 when I had my first one I will have my son try it.
